If statement that tests if a value is in range?
Hi I am trying to write a code that tests if a value is within a range of values
For example, I record a value, lets say x=20
I want an IF statement that checks if X is between 10 and 30
FWIW, x is a value that is taken from a sensor.
IF 30 > x > 10
   y=pass;
   y=fail;
However when I put the code in it fails, can anyone tell me what I am doing wrong?
Thanks
if (myVal > lowerBound && myVal < upperBound) {
else {
...R
Be careful to use < or <= depending if you want the borders of the range to be included.
If you use this range checking a lot you might put it in a function
bool inRange(int val, int minimum, int maximum)
  return ((minimum <= val) && (val <= maximum));
// example usage
int x = analogRead(A0);
if ( inRange(x, 0, 200) )
Thanks for the replys, I have read the examples and I feel like the code is right now but it still doesnt display on the LCD. It does not throw errors it just doesnt display.
The code I am speaking about I put markers in the program to help identify. The markers look like this //---------------------------
Thanks
#include <LiquidCrystal.h>
//LiquidCrystal  RS, E, 4,  5,  6, 7);
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);       // put your pin numbers here
const int button = 2; //Defines the button as output 11
const int handpiece = 4; // Defines the handpiece as output 13
const int valve = 3; //Defines the valve as output 12
const int delay1 = 5000; //time to leave the handpiece on before testing
const int delay2 = 5000; //time to leave the valve on
const int delay3 = 10000; //time to leave results on screen
int buttonstate = 0;
// the setup routine runs once when you press the button
void setup() {            //This function gets called when the Arduino starts
  lcd.begin(20, 4);                          // put your LCD parameters here
  lcd.print("Press Button");
  lcd.setCursor(0,1);
  lcd.print("To Start Test");
  pinMode(button, INPUT_PULLUP);
  digitalWrite(button, HIGH); //Powers the button
  pinMode(handpiece, OUTPUT);
  digitalWrite(handpiece, LOW);    // Verifies handpiece is off
  pinMode(valve, OUTPUT);
  digitalWrite(valve, LOW);    // Verifies valve is off
double Thermister(int RawADC) {  //Function to perform the fancy math of the Steinhart-Hart equation
  double Temp;
  Temp = log(((10240000 / RawADC) - 10000));
  Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp )) * Temp );
  Temp = Temp - 273.15;              // Convert Kelvin to Celsius
  Temp = (Temp * 9.0) / 5.0 + 32.0; // Celsius to Fahrenheit - comment out this line if you need Celsius
  return Temp;
  buttonstate = digitalRead(button);
  if (buttonstate == LOW) {
  lcd.clear();
  //Display Test Running
  lcd.print("Test");
  lcd.setCursor(0,1);
  lcd.print("Running");
    digitalWrite(handpiece, HIGH);   // turn the handpiece on
    delay(delay1);               // time to leave handpiece on
    //Take Speed Reading
    int tach = analogRead(A0);
    float tachvoltage = (tach * (5.0 / 1023.0))*20000;
    //Take Sound Reading
    int sound = analogRead(A1);
    float soundvoltage = (sound * ((5.0 / 1023.0)) * 100)-13;
    //Take Temp Reading
    double temp;
    int temperature = analogRead(A2);
    temp = Thermister(temperature);
    digitalWrite(valve, HIGH);   // turn the valve on
  lcd.clear();
  lcd.print("Check for A1");
  lcd.setCursor(0,1);
  lcd.print("Alert on Console");
    delay(delay2);               // time to leave valve on
    digitalWrite(valve, LOW);    // turn the valve off
    digitalWrite(handpiece, LOW);    // turn the handpiece off
  lcd.clear();
  lcd.print("Test");
  lcd.setCursor(0,1);
  lcd.print("Completed");
  delay(2000);
  lcd.clear();
 //Display Temperature
  lcd.setCursor(0,0);
  lcd.print("Temp");
  lcd.setCursor(6,0);
  lcd.print(temp);
  lcd.setCursor(12,0);
  lcd.print("Deg F");
  //Display Speed
  lcd.setCursor(0,1);
  lcd.print("Speed");
  lcd.setCursor(6,1);
  lcd.print(tachvoltage);
  lcd.setCursor(15,1);
  lcd.print("RPM");
  //Display Sound
  lcd.setCursor(0,2);
  lcd.print("Sound");
  lcd.setCursor(6,2);
  lcd.print(soundvoltage);
  lcd.setCursor(12,2);
  lcd.print("dB");
  delay(delay3);
  lcd.clear();
if (tachvoltage > 79000 && tachvoltage < 81000) {
  lcd.print("Speed Result");
  lcd.setCursor(14,0);
  lcd.print("Pass");
else {
  lcd.print("Fail");
  lcd.clear();
  lcd.setCursor(0,1);
  else {
My gues would be, that you never get a tachvoltage value within your range.
Try widen the range to a much larger interval, to test if you get something, just for debugging.
First, your Thermister() function is designed to return a double, which really doesn't exist for the Arduino, so you may as well make it a float. Second, any time you have a complex expression using floating point numbers, you may as well make them all floating point constants:
    float tachvoltage = (tach * (5.0 / 1023.0))*20000.0
While it probably doesn't make any difference here, if that calculation was in a tight loop, if would be more efficient to write the statement as:
    float tachvoltage = tach * 97.75171;
since there are two constants and a divide operation is relatively slow.
Anders53:
The value is outside the range currently, but shouldnt it show "Fail" when its outside the range?
Spoolx:
YES it should, your are quite right !
I take it thats exactly your problem that it does not write ANYthing in that if statement ?
I would presume it is a problem with your cursor setting then.
Not to be pedantic - does your LCD works / display simple "hello word"? ( Or your setup text?)
econjack:
No, that will make absolutely no difference whatsoever. All the math on the constants is done by the compiler, leaving only the one multiply by tach to be done at run-time. The code that actually ends up on the Arduino will do exactly what you have written, without having to modify the source code.
Regards,
Ray L.
Vaclav:
Everything works with the exception of the code I segregated in the above post.
Basically it displays all my results but does not display anything in this segment.
  lcd.print("Pass");
else {
  lcd.print("Fail");
Could it be the multiple if statements?
double post
...and it's the "little stuff" marked with fancy comments lines that gets missed most often.
Don't feel bad - been there , done that.
And this snippet is not the only one - check the end and start of the loop().
@Ray: Is that always the case? I thought I remembered looking at the assembler a few years ago and saw that the constants weren't factor. I'm getting old, so I could be wrong.
Delta_G:
Expand your vision a little...
What does the very next line, executed a few microseconds after that stuff get printed tell the lcd to do?
      lcd.print("Pass");
    else {
      lcd.print("Fail");
    lcd.clear();
ouch... guess I need a delay, thanks I will try that asap
