If statement thermometer
This is my first ever post and project. I am working on adding an if/else statment to my thermostat. Though I know this is probably a simple issue, I am trying to have some parameters to go off when the sensor reports certain values for my board. by using an if statement I am able to turn on an LED when the sensor reports a value of above 80 degrees F, but i am unable to turn it off when the sensor reports a value below 80 degrees F. Could someone help me shut off the LED. I've tried using a else statement but it wont accept it. Any help would be appreciated; thanks!
const int temperaturePin = 0;
  pinMode(13,OUTPUT);
  float voltage, degreesC, degreesF;
  voltage = getVoltage(temperaturePin);
  degreesC = (voltage - 0.5) * 100.0;
  degreesF = degreesC * (9.0/5.0) + 32.0;
  Serial.print("voltage: ");
  Serial.print(voltage);
  Serial.print("  deg C: ");
  Serial.print(degreesC);
  Serial.print("  deg F: ");
  Serial.println(degreesF);
  if(degreesF > 80)
    digitalWrite(13,HIGH);
  delay(2000);
float getVoltage(int pin)
  return (analogRead(pin) * 0.004882814);
Look into the "ELSE" statement.
Essentially, if it's not above 80, the ELSE condition will turn off the LED.
Post the code you tried.
When you sort out the "if" you'll find it's likely a good idea to leave a few degrees' gap between the off and on, ie not just on > 80 and off <= 80, since then at 80 it will flicker as it changes minutely between 80 and 80.1. That slight gap is known as hysteresis.
  if(degreesF > 80)
} else if(degreesF < 78){
digitalWrite(13,LOW);
Serial.println("In between, just wait a little longer!");
How about now?
Thanks for the quick replies guys; It works! with the limits C-F-K wrote it now shuts on and of with the desired parameter temperatures. Glad to get such quick responses
