hello,
is It possible to take an input value that sitting at X value and use something like a IF statement to look for Y change?
IF X or 100 changes + or - 1 (Y) // (99 or 101) then run {}
or
IF X or 100 changes + or - 5 (Y) //(95 or 105) then run {}
keep in mind the input will change so the 100 or X value will be trigger IF change is by 1 or 5 or whatever I set it Y too
so if I turn a POT it will only run IF the change is by Y much
thanks
if (value >95 && value <105){
// action
or
if (value >=95 && value <+105){
// action
Yes.
For details, look up the function abs(...) and/or look up the logical operators.
CrossRoads probably meant for the <+105 to be <=105 .
sorry, you misunderstood ill try explain better
I don't what to present the range.
I want to say if the X value which is an analogue input. changes by Y amount, be it 1, 5, 10 then run if or other command.
if set to 5 then when input X = 100 and it changes to 101 nothing or 102 nothing. until it sees 105
BUT as I said X changes as input so I only want a trigger when its more then Y amount
thanks
CrossRoads:
// action
or
// action
thanks , this is something of what I was thinking...
it works...BUT if the input changes to quick it will skip the IF
//works only when pot changes
if (val - valnew ==2)
{ lcd.print(" "); valnew = val; myservo.write(valnew);}
delay(10);
it needs to go both ways and if the value changes the other way I get a NEGATIVE and it wont work.
Delta_G:
So you need to keep track of the old value and save it when you read a new value. Simple subtraction tells the difference between the two.
if(oldValue - newValue >= 5)
Or wrap that whole expression in abs() if you want plus or minus.
Delta_G:
Being able to read has its advantages.
if(abs(oldValue - newValue) >= 5)
