Not sure if right place but struggling with some code. I have a 3x4 keypad setup to flash an LED a number of times depending on the button and that's working as expected but I would like to compact it a bit and I would like to be able to cancel one if a different button is pressed.
How can I start the if again or repeat it without having 'output high delay output low delay' 8 times and how would I cancel it to tart another?
Thanks in advance
#include <Keypad.h>
int off;
const int ledPin = 13;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {2, 3, 4, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
pinMode(ledPin, LED_BUILTIN);
void loop(){
char key = keypad.getKey();
if (key=='*'){
Serial.println("*");
digitalWrite(ledPin, LOW);
if (key=='1'){
Serial.println("1");
digitalWrite(ledPin, HIGH);
if (key=='2'){
Serial.println("2");
if (key=='3'){
Serial.println("3");
if (key=='4'){
Serial.println("4");
if (key=='5'){
Serial.println("5");
if (key=='6'){
Serial.println("6");
if (key=='7'){
Serial.println("7");
if (key=='8'){
Serial.println("8");
if (key=='9'){
Serial.println("9");
if (key=='0'){
Serial.println("0");
if (key=='#'){
Serial.println("#");
delay(2000);
