i want to add if statement under case 1 ,2 and 3 but can't compile. please help !
const int buttonPin = 4; // number of the pushbutton pin
const int ledPin = 13; // number of the LED pin
const int ledPin1 = 12;
const int ledPin2 = 11;
const int pin = 2; // pushbutton pin for trigger relay
const int relay = 5; // relay
// variables will change:
int initial = 0; //hold current initial
int oldstate = 0; //hold last initial
int buttonstate = 0; // variable for reading the pushbutton status
pinMode(ledPin, OUTPUT); // initialize the LED pin as an output:
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(buttonPin, INPUT); // initialize the pushbutton pin as an input:
pinMode(pin, INPUT_PULLUP);
pinMode(relay, OUTPUT);
long offAt = 0;
void loop(){
//debouncing routline to read button
buttonstate = digitalRead(buttonPin); //state the initial of button
if(buttonstate == HIGH){ //check if it has been pressed
delay(50);
buttonstate = digitalRead(buttonPin);//state button again
if(buttonstate == LOW){ //if it is 0 considered one press
initial = oldstate + 1; //increase initial by 1
}else{ //check if it has been NOT pressed
delay(100);
switch (initial){ //react to button press a initial
case 1: //if initial is 1
digitalWrite(ledPin, HIGH);//on
digitalWrite(ledPin1, LOW);//off
digitalWrite(ledPin2, LOW);//off
oldstate = initial; //set oldstate initial as current initial
if (digitalRead(relay) == LOW ) && (digitalRead(pin) == LOW)
digitalWrite(relay, HIGH);
offAt = millis() + 5000; //store var of now + 5 seconds
case 2:
digitalWrite(ledPin, LOW);
digitalWrite(ledPin1, HIGH);
oldstate = initial;
case 3:
digitalWrite(ledPin2, HIGH);
oldstate = initial;
default: //if initial is not 1 2 3
digitalWrite(ledPin, LOW); //off
oldstate = 0; //reset to all off/initial 0
