IF statement with boolean
Hello guys
I’ve ran into a bit of trouble, the current code (posted below) checks the temperature and opens/closes a valve depending on the users input temperature (userTemp). Currently I can get the higher/lower if statement to function depending on the value the user wishes, however the first if statement that outputs ‘temperature is good’ always runs too. How can I implement a boolean true/false into this so it is only ran when between the two values?
//Initialisation
//Variables defined
float temp;             // decimal value for read temperature from LM35
int userTemp = 30;          //this will be input to user via bluetooth
int minusBufferTemp;          //float for minus buffer zone
int addBufferTemp;            //float for plus buffer zone
int val = 255;          //speed of the motor between 0 and 255... anything less than 200 does not run.
float bufferVal =  2;
//Pin definitions used
int motorPin1 = 2;      //enable pin for motor in l293
int motorPin2 = 3;      //enable pin for motor in l293
int enablePin = 9;      // enable pin for l293
int tempPin = 0;        //Temperature pin for LM35
  Serial.begin(9600);                // begin serial output
  pinMode(motorPin1, OUTPUT);        // enable motorpin output
  pinMode(motorPin2, OUTPUT);        // enable motorpin output
  pinMode(enablePin, OUTPUT);        // set enable pin as output
  digitalWrite(enablePin, LOW);      //lower enable for l293 pin so motor does not run
  // put your main code here, to run repeatedly
  temp = readtemp();
  Serial.print(temp);
  Serial.print("*C");
  //Calculations for temperature buffer zone.
  float minusBufferTemp = userTemp - bufferVal;
  float addBufferTemp = userTemp + bufferVal;
 int test = (temp > minusBufferTemp && temp < addBufferTemp)
if (test);
  Serial.println("Temperature is good");
  //Close Valve
  analogWrite(enablePin, val);
  digitalWrite(motorPin1,LOW);
  digitalWrite(motorPin2, HIGH);
  if(temp < minusBufferTemp)
    Serial.println("Temperature is Lower");
    Serial.println(temp);
    //OPEN VALVE
    digitalWrite(motorPin1,HIGH);
    digitalWrite(motorPin2, LOW);
  else {
    if( temp > addBufferTemp)
      Serial.println("Temperature is higher");
      //CLOSE VALVE
      digitalWrite(motorPin1, LOW);
int readtemp()      {
  temp = analogRead(tempPin);
  return temp = round(temp * 0.48828125);
Thanks in advance.
is missing a ;
if (test);
has a useless ;
PaulS:
is missing a ;
if (test);
has a useless ;
:o That was easier than expected, thanks very much!
EDIT: To clarify I also removed the second if statement from in between the {} and it worked. Now to try and measure resistance of the motor when the valve is fully open!
When the useless comments do not match the code, the comments are worse than useless.
