I have surround sound that doesn't have remote control option but I have attached a motor to the knob with arduino and have an IR receiver. From the examples I have found I have been unable to get a working if statement for a signal from the IR receiver.
Please let me know if you need additional information.
Seeing the code would be helpful.
Did you read this before posting a programming question ?
Here is the complete/ but short code for the using the project with serial monitor (as well as what I understand of IRreciever).
#include <IRremote.h>
#include <IRremoteInt.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
int motorSpeed;
boolean muteToggle;
byte x;
pinMode(2, OUTPUT); //direction switch
pinMode(3, OUTPUT); //direction switch
pinMode(9, OUTPUT); //speed control
irrecv.enableIRIn(); //start the reciever
muteToggle = true;
motorSpeed = 0;
byte x = Serial.read();
if (x == B00111000) { //8
volumeUp();
if (x == B00110010) { //2
volumeDown();
if (x == B00110101) { //5
if (muteToggle == true) {
mute();
if (muteToggle == false) {
unMute();
muteToggle = !muteToggle;
irrecv.resume(); // Receive the next value
void volumeUp() {
digitalWrite(2, HIGH);
digitalWrite(3, LOW);
motorSpeed = 200;
analogWrite(9, motorSpeed);
delay(236);//volume up
motorSpeed = 0;
muteToggle = true;
void volumeDown() {
digitalWrite(2, LOW);
digitalWrite(3, HIGH);
motorSpeed = 200;
delay(450); //volume
motorSpeed = 0;
muteToggle = true;
void mute() {
motorSpeed = 200;
delay(12000);
motorSpeed = 0;
void unMute() {
motorSpeed = 200;
motorSpeed = 0;
Here is the blog post and IR product I am using.
http://tech.yeesiang.com/receive-ir-value-with-arduino/
I want pressing "+", "-" and mute within if statements.
Whaaaaa? Aren't you looking for IR input?
I was using serial monitor for troubleshooting and forgot to re-include the IR remote aspect. The hex codes are different as my remote is different than the one in the blog post above.
int RECV_PIN = 11;
int motorSpeed;
boolean muteToggle;
char x;
word HEXcode;
muteToggle = true;
motorSpeed = 0;
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
HEXcode = (results.value, HEX);
if (HEXcode == "FD807F"({
volumeUp();
if (HEXcode == "FD906F"({
volumeDOWN();
if (HEXcode == "FDA05F"({
mute();
unMute();
volumeUp();
volumeDown();
mute();
unMute();
void volumeUp() {
motorSpeed = 200;
motorSpeed = 0;
muteToggle = true;
void volumeDown() {
motorSpeed = 200;
motorSpeed = 0;
muteToggle = true;
void mute() {
motorSpeed = 200;
delay(12000);
motorSpeed = 0;
void unMute() {
motorSpeed = 200;
motorSpeed = 0;
Hopefully this is enough to get the problem solved.
system
December 26, 2015, 1:44pm
6
The compiler barfed big time on that.
What's wrong with
if (results.value== 0xFD807F){
Yeah, that was me who barfed. Thanks, problem solved.
