I am writing some code for my serial VT100 TFT display (Byvac4629).
Now i have added some code for the buttons and the serial output of the button variables, but it doesn't work and i really don't know what to do anymore.
All i know is that it has something to do with the "return;" command being in the wrong place. Can anyone tell me what i do wrong?
Here is the sub-function code.
What kind of button it this? A contact button? If so, are there multiple in series with resistors? A good clear discription of both your code and project will help us greatly.
The 'return;' shouldn't be a problem since the only thing after it is a bunch of close-brackets. After those close-brackets the function will return anyway.
I think your bracketing was a bit wonky. Try this instead:
I want this code to check the analog buttonpin for a value (every button has a different value). Then when a certain button is pushed the coupled var needs to be updated + or - "1" and the updated value is send to the display. Then a delay for X seconds. Then the text is being removed by drawing a black bar over it.
as for what it accually does.... nothing!
The program crashes or gets stuck before anything is send to the display. It DOES goes through the setup though!
here is my complete sketch:
// Setup settings
#define DISP_WIDTH 220
#define DISP_HEIGHT 320
#define BUFSZ 64
int dataA[DISP_HEIGHT]; // data gelezen uit analoog input (2 tabellen)
int dataB[DISP_HEIGHT];
int sample_delay = 0; // tijd tussen metingen analoog input
int analog_range = 1024; // bereik van de analoog input
int skip = 4 ; // spatie tussen punten
int offset = 180;
int calibration = -5;
// DO NOT TOUCH!!!
int vMin=1024;
int vMax=0;
int vMed=0;
int D1=0;
int D2=0;
int D3=0;
const int buttonPin = A7; // the number of the pushbutton pin
//const int samplePin = 4;
int buttonState = 0; // variable for reading the pushbutton status
//int sampleState = 0; // variable for reading the pushbutton status
int scaling = 0;
int y = 0;
int z = 0;
pinMode(buttonPin, INPUT);
//pinMode(samplePin, INPUT);
Serial.begin(2000000);//,0,'*');
Serial.write("\n"); //send <CR>
//Serial.begin(115200);
Serial.write("\e[?25I"); // Hide cursor
delay(2000);
Serial.write("\e[?10P"); // portrait
Serial.write("\e[2J"); // clear screen
delay(400);
//Serial.write("\e[?10L"); //set landscape mode
Serial.write("\e(6"); // set fontsize to 5 points
Serial.write("\e[63;63;0f\e{215 0p\e{215 320L");
Serial.write("\e[63;63;0f\e{5 4p");
Serial.write("|min V |med V |max V ");
delay(100);
Serial.write("\e[63;63;63f DSO");
//#define analogReference(EXTERNAL);
// TE TRAAG!
void sample() {
int i;
//int K = analog_range - analogRead(A0);
//delay(sample_delay);
//int L = analog_range - analogRead(A0);
//int M = analog_range - analogRead(A0);
//if (analog_range - analogRead(A0) < 3){// && (L > K)){// && (K > M)){
for (i = 0; i < DISP_HEIGHT / skip; ++i)
int vA;
int vB;
vA = analog_range - analogRead(A0); // voor "+" waarde
vB = analog_range - analogRead(A1); // voor "-" waarde
dataA[i] = vA;
dataB[i] = vB;
void buttoncheck() {
char buf[BUFSZ];
int char_number = 0;
buttonState = analogRead(buttonPin);
if (buttonState > 975){ // UP
scaling = scaling + 1;
delay(2);
snprintf(buf, BUFSZ,"\e{15 225pZOOM= %dx", scaling*10);
Serial.write(buf);
delay(750);
Serial.write("\e[0;0;0f\e{2 225 254 319F");
if ((buttonState > 900)&&(buttonState < 950)){ // LEFT
sample_delay=sample_delay+1;
delay(2);
snprintf(buf, BUFSZ,"\e{15 225pSAMPLE-TIME= %dms", sample_delay);
Serial.write(buf);
delay(750);
Serial.write("\e[?10P"); //set landscape mode
//else{
if ((buttonState > 820)&&(buttonState < 870)){ // DOWN
scaling = scaling - 1;
delay(2);
Serial.write(buf);
delay(750);
if (scaling < 0){
scaling = 0;
delay(20);
Serial.write("\e{15 225pZOOM SET TO HIGHEST!");
delay(1500);
delay(2);
//else {
if ((buttonState > 750)&&(buttonState < 790)){ // RIGHT
sample_delay=sample_delay-1;
delay(2);
Serial.write(buf);
delay(750);
Serial.print("\e[0;0;0f\e{2 225 254 319F");
if (sample_delay < 1){
sample_delay = 0;
//char_number = 26; // NUMBER OF CHARACTERS IN THE MESSAGE
delay(2);
Serial.print("\e{15 225pSAMPLE-TIME SET TO FASTEST!");
delay(1500);
delay(2);
void displine() {
int i=0;
int vA;
int vB;
char buf[BUFSZ];
float vA = dataA[i];
float vB = dataB[i];
//offset = v - (DISP_WIDTH / (2*analog_range));
y = (vA * DISP_WIDTH / (4096));
z = (vB * DISP_WIDTH / (4096));
/* if (y < 35){
y =35;
if (y > 205){
y =205;
if (z < 35){
z =35;
if (z > 205){
z =205;
if (vMax < (512 - (vA/2))){// && (vMax > vMin)){
vMax =512 - (vA/2);
if (vMin > (512 - (vA/2))){// && (vMin < vMax)){
vMin =512 - (vA/2);
vMed =((vMax + vMin) / 2);
snprintf(buf, BUFSZ,"\e[0;0;0f\e{0 %dp\e{205 %dL\e[0;63;0f\e{%d %dP", i*skip, i*skip, (-y + (y / 10) * scaling)- offset +(calibration * scaling), i*skip - skip);
Serial.write(buf);
delay(2);
snprintf(buf, BUFSZ,"\e{15 %dp\e[63;35;0f\e{%d %dP", i*skip, (-z + (z / 10) * scaling)- offset +(calibration * scaling), i*skip - skip);
Serial.write(buf);
delay(2);
if (i >= DISP_HEIGHT){
i=0;
//snprintf(buf, BUFSZ, "\e[0;0;0f\e{35 %dp\e{205 %dL", i*skip, i*skip);
//Serial.write(buf);
// vMin=1024;
//vMed=0;
//vMax=0;
vMin=1024;
vMed=0;
vMax=0;
//readFast(10);
sample();
displine();
buttoncheck();
// buttons();
if (vMin < D3){
Serial.write("\e[0;20;63f\e{55 4p"); Serial.print(D3);
//Serial.write(" "); //write space to delete old characters on screen
delay(8);
if ((vMed > D2)||(vMed < D2)){
float D2= vMed * (5.0 / 2048.0);
Serial.write("\e[0;63;0f\e{145 4p"); Serial.print(D2);
delay(8);
if ((vMax > D1) || (vMax==1024)){
float D1= vMax * (5.0 / 2048.0);
Serial.write("\e[63;0;0f\e{238 4p"); Serial.print(D1);
delay(8);
Serial.write("\e[?10P"); //set Portrait mode
D1=vMax;
D2=vMed;
D3=vMin;
delay(8);
Serial.flush();
Thank you, i tried your adjusted code, but still no difference in running. allthough i am certain that your version is better than mine. i guess there must be another problem
as for the buttons:
i indeed use the series resistor, multiple buttons on one pin type of setup
After some more testing i found out that when i put a "return;" at the end of the first "if" statement for the buttons, that one button works. (and the main program works again...)
In the next piece of code the uncommented code works fine. As soon as i put text in the data that is beeing send over serial, there occurs a problem and the program crashes.
in any other place in my code the text sending works fine! even right above this code!
Anyone an idea?
while (scaling <= 1) {
scaling = 1;
//delay(200);
//Serial.write("\e{15 225p ALLREADY THE HIGHEST!");<------------THIS CRASHES THE PROGRAM
//delay(750);
Serial.write("\e[0;0;63f\e{2 225 254 319F"); <--------------THIS WORKS, BUT IF I ADD TEXT HERE IT CRASHES
//Serial.write("\e[?10P"); //set landscape mode
//delay(20);
yes the serial port seems to handle this speed quite nicely. my display works best at this speed. and arduino copes fine with it..
What Arduino do you have? Running at what clock speed? According to the Atmega328P datasheet, running at 16 MHz (which is pretty typical) the maximum baud rate is 1 MBps. (Page 203).
This will trick the compiler into leaving the string constants in FLASH and not copy them to SRAM to print.
(I can't tell if the .write() method supports the F() macro or not. Fortunatelt, .print() does the same as .write() for string constants.)
INDEED! this was the problem! it is working fine now! i would have never come up with this on my own. Thank you!
For now i have only added the (F(... in the buttoncheck.
can there be negative consequences to using this in my whole sketch?
No. Indeed, since you're clearly close to the edge in terms of SRAM consumption it would be a good idea to extend its use or when you next tweak the code, you may find yourself in trouble again.
