If statement with the condition of if a certain keyboard input is pressed
Hi, I am trying to make my servo turn 90 degrees if I press for example, 'n'. I can't figure out how to though. I thought I could do
if (Keyboard.press = 'n'){
  servo1.write(90);
but it doesn't work. Arduino IDE keeps saying
'Keyboard not found'. Does you sketch contain the line '#include <Keyboard.h>'
Here's the full code:
#include <Servo.h>
Servo servo1;
int servoPin = 9;
void setup(){
  Keyboard.begin;
  servo1.attach(servoPin);
void loop(){
      servo1.write(90);
Welcome to the forum
Which Arduino board are you using ?
You have used the wrong syntax for the Keyboard functions. For instance
Keyboard.begin;
should be
Keyboard.begin();
also, the press() function simulates the pressing of a key rather than reading whether a key is pressed and, anyway, in C, == is used for comparison of values rather than =
Hi there, I'm using an Arduino Uno R3. I just started learning Arduinos. Can I ask what function is used to read if a key is pressed?
Then the Keyboard library will not work (wrong processor) , nor do you need it
To determine whether a key has been pressed you can do something like this
  if (Serial.available()) //if a character is available to read
    char inChar = Serial.read();  //read the character
    if (inChar == 'n')  //test the character
      Serial.println("you pressed n");
Right mate, thanks. I got it working after modifying your code. I can't thank you enough.:grin:
Hello
I´m using this small sketch to set values into a sketch during testing.
void checkKeyboard() {
  if (Serial.available()) {
    switch (Serial.read()) {
      case '1':  break;
      case '2':  break;
      case '3':  break;
      case '4': break;
      case '5':  break;
      case '6': break;
Have a nice day and enjoy programming in C++ and learning.
Дайте миру шанс!
You are welcome
