IF statement with two ANDed conditionals
To preface, I have been working with an Arduino for about a year now and I have this stupid problem(no, not my cousin Bill). I have an IF statement with two expressions that need to be true for the IF statement two be true. I've tried the following:
if(-100 <= dataIn <= 100 && Serial.available() == 0)
and...
if((-100 <= dataIn <= 100) && (Serial.available() == 0))
and a few others out of desperation. I know I did this before but it is only analyzing the second expression (the Serial.available() one). Can somebody slap some sense into me?
Also, I just noticed spellcheck doesn't recognize "Arduino" in the posts.
This
does not do what you think. Each sub-expression should have only a single comparison:
((dataIn >= -100) && (dataIn <= 100))
There are, literally, thousands of web pages with tutorials on c/c++ expression syntax....
Regards,
Ray L.
Thanks, I knew it was something stupid. I needed that. Just goes to show, smart (-ish in my case) people can do dumb things.
I would write:
if(! Serial.available() && (dataIn >= -100 && datain <= 100))
if NOT Serial.available() AND datain is between -101 and 101.
I would write
Serial.available() does not return a boolean, so I hate to see code written that way.
if(Serial.available() > 0 && (dataIn >= -100 && datain <= 100))
is how I would write it. That shows that you KNOW what the value that Serial.available() returns means.
Of course, I probably would NOT combine what are two completely unrelated clauses in one if statement.
if(Serial.available() > 0)
   if(dataIn >= -100 && datain <= 100)
is how I would really write it (if that made sense; it's hard to tell from a snippet).
Those compound IF statements can also catch you out if they are followed by an ELSE
...R
Exactly. That's why I rarely use compound if statements, except to check a range. The else clauses of nested if statements can tell you exactly why a particular path was not chosen, without the need for even more if statements to sort that out.
