IF statement
In the following code, the output must be only one because of IF loop but I am getting all the output at once. So please help me
#include <SoftwareSerial.h>
#define txPin  4
//Create a Softspeakjet Objet
SoftwareSerial speakjet = SoftwareSerial(0, txPin);
const int ap0 = A0;  // input pins
const int ap1 = A1;
const int ap2 = A2;
const int ap3 = A3;
const int ap4 = A4;// input pins
const int th2 =340 ;
const int th4 =200 ;
char m6[]={20, 96, 21, 114, 22, 88, 23, 5, 183, 7, 159, 146, 164}; //hello
char m1[]={20, 96, 21, 114, 22, 88, 23, 5, 132, 132, 176};  //one
char m2[]={20, 96, 21, 114, 22, 88, 23, 5, 8, 191, 162};  //two
char m3[]={20, 96, 21, 114, 22, 88, 23, 5, 8, 190, 148, 8, 128};  //three
char m4[]={20, 96, 21, 114, 22, 88, 23, 5, 186, 7, 137, 153};  //four
char m5[]={20, 96, 21, 114, 22, 88, 23, 5, 186, 157, 166};  //five
  //Configure the pins for the speakjet module
  pinMode(txPin, OUTPUT);
  //Set up a speakjet port to talk from Arduino to the speakjet module on pin 3.
  speakjet.begin(9600);
  int av0 = analogRead(ap0);
  int av1 = analogRead(ap1);
  int av2 = analogRead(ap2);
  int av3 = analogRead(ap3);
  int av4 = analogRead(ap4);
  if (((av0 > th2)&&(av1 < th4)&& (av2 > th4)&& (av3 > th4)&& (av4 > th2))== 1 )
    speakjet.println(m1);
    delay(2000);
    exit;
  else if (((av0 > th2)&&(av1 < th4)&& (av2 < th4)&& (av3 > th4)&& (av4 > th2))== 1 )
    speakjet.println(m2);
    delay(2000);
    exit;
  else if (((av0 > th2)&&(av1 < th4)&& (av2 < th4)&& (av3 < th4)&& (av4 > th2))== 1 )
    speakjet.println(m3);
    delay(2000);
    exit;
  else if (((av0 > th2)&&(av1 < th4)&& (av2 < th4)&& (av3 < th4)&& (av4 < th2))== 1 )
    speakjet.println(m4);
    delay(2000);
    exit;
  else if (((av0 > th2)&&(av1 > th4)&& (av2 > th4)&& (av3 > th4)&& (av4 > th2))== 1 )
    speakjet.println(m5);
    delay(2000);
    exit;
    speakjet.println(m6);
    delay(2000);
    exit;
  delay(2000);
Some debug prints might prove useful.
How does this even compile?
exit should be exit()
vaj4088: How does this even compile?
Written without the parens it's just a pointer. Totally useless and does nothing but it is legal.
Delta_G: Written without the parens it's just a pointer. Totally useless and does nothing but it is legal.
When I took C in college, way way back, I remember my teacher saying,
C will not only let you hang yourself, it will cheerfully hand you the rope!
The result of a comparison operator is not an integer, its a truth value, why are you comparing to 1 ?
You can rewrite
as
  if (av0 > th2 && av1 < th4 && av2 > th4 && av3 > th4 && av4 > th2)
which is much clearer and less cluttered without the spurious parentheses and ==1.
