If Statements not responding when receiving an input
Hello, I'm currently running into an issue where even though I've verified that my Arduino is receiving a propper 5v signal from the propper input pin, the code is still skipping right over the if statement which the said signal should activate. theirs no issue with the wiring as I'm doing a direct jumper w a 5v signal to simulate for the program.
Blockquote
#include <Stepper.h>
int StartMotor = 3;
int reverseMotor = 4;
const int stopmotor = 22;
int RMotorStep = 50;
int RMotorDir = 52;
int LMotorStep = 51;
int LMotorDir = 53;
int DOctrl = 30;
pinMode(stopmotor, INPUT);
pinMode(reverseMotor, INPUT);
pinMode(StartMotor, INPUT);
pinMode(DOctrl, INPUT);
pinMode(RMotorStep, OUTPUT);
pinMode(RMotorDir, OUTPUT);
pinMode(LMotorStep, OUTPUT);
pinMode(LMotorDir, OUTPUT);
START:
//reviewing inputs and outputs
Serial.print("time to work"); //looping text before sub actions start
delay(2000);
digitalRead(StartMotor);
digitalRead(reverseMotor);
digitalRead(stopmotor);
if (StartMotor == HIGH)
digitalWrite(RMotorStep, HIGH);
digitalWrite(RMotorDir, HIGH);
digitalWrite(LMotorStep, HIGH);
digitalWrite(LMotorDir, HIGH);
Serial.print(" Motors goin Forward ");
delayMicroseconds (100);
goto START;
else if (reverseMotor == HIGH)
digitalWrite(RMotorDir, LOW);
digitalWrite(LMotorDir, LOW);
Serial.print(" Motors reverse ");
goto START;
else if (stopmotor == HIGH)
Serial.print(" Motors stopopopop ");
goto START;
} else
Serial.print("gotta reset");
delay(1500);
goto START;
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
StartMotor is a pin number, not the state of that pin. Did you mean
if (digitalRead(StartMotor) == HIGH)
Thank you, yup that's what I meant.
It helps considerably if you give move descriptive names to variables such as
const byte startMotorPin = 3;
In passing, note the use of a byte rather than an int to save memory and the fact that, as the value will not change the variable has been declared as a constant value
And please, get rid of the gotos.
Hello, Sorry for the hiatus just getting back. down below is the new improved program. although I'm having an issue when running it. occasionally while running it will cycle through the start motor section, without having anything plugged in. is this a hardware issue, or does it happen on others Arduino as well? on arduino mega
const byte StartMotor = 4;
const byte reverseMotor = 16;
const byte stopmotor = 39;
int RMotorDir = 52;
int LMotorDir = 53;
int DOctrl = 30;
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 50, 51, 52, 53);
  digitalWrite(RMotorStep, LOW);
  digitalWrite(LMotorStep, LOW);
  myStepper.setSpeed(200);
  delay(250);
  digitalWrite(StartMotor, LOW);
  digitalWrite(reverseMotor, LOW);
  digitalWrite(stopmotor, LOW);
  delay(100);
  Serial.print(" Motor Home ");
  myStepper.step(0);
  if (digitalRead(StartMotor) >= HIGH)
    delayMicroseconds (50);
    myStepper.step(-200);
  else if (digitalRead(reverseMotor) >= HIGH)
    delay(200);
    myStepper.step(200);
  else if (digitalRead(stopmotor) >= HIGH)
    myStepper.step(0);
    delay(100);
    Serial.print("motor home");
    delayMicroseconds (200);
That's very . . . defensive.
Do you have a pull-down resistor on the StartMotor pin?
no, that was my answer when == was doing the same thing
"no" you don't have a pull-down?
no, I don't have a pull-down resistor. to add one, would that just be attaching it in series to the incoming 5v signal?
