if statements returns HIGH
Why does all of my if statements return HIGH when nothing is a attached?
#include <Keyboard.h>
const int buttonGreen = 2;
const int buttonRed = 3;
const int buttonYellow = 4;
const int buttonBlue = 5;
const int buttonOrange = 6;
const int volt = 7;
// variables will change:
int buttonstateGreen = 0;
int buttonstateRed = 0;
int buttonstateYellow = 0;
int buttonstateBlue = 0;
int buttonstateOrange = 0;
 Keyboard.begin();
  buttonstateGreen = digitalRead(buttonGreen);
  buttonstateRed = digitalRead(buttonRed);
  buttonstateYellow = digitalRead(buttonYellow);
  buttonstateBlue = digitalRead(buttonBlue);
  buttonstateOrange = digitalRead(buttonOrange);
 if(buttonstateGreen == HIGH){
  Keyboard.write('A');
 if(buttonstateRed == HIGH){
  Keyboard.write('S');
 if(buttonstateYellow == HIGH){
  Keyboard.write('D');
 if(buttonstateBlue == HIGH){
  Keyboard.write('F');
 if(buttonstateOrange == HIGH){
  Keyboard.write('G');
How are your buttons wired to the Arduino? Between Vcc and pin or between pin and GND? Are you using pull-down or pull-up resistors?
Also, take a peek at the pinMode() function.
sterretje:
Right now I have nothing hooked up to the arduino for debugging purposes
Does the sketch compile?
Where is loop()
Nothing connected, do you know about floating pins?
fluff113:
Because they've got to return something. Why would you expect them to not be HIGH?
Hey fluff. I know it was subtle, but read reply #2 again, and sus out what it means.
Nothing connected to the pins and no pinMode()s equals floating pins, which means any state is possible and HIGH is quite likely.
