IF Statment
I think this might be easy but I realy need help with it. In my code, I set a motor to run as soon as the value of the anlog pin goes below a certain value. however, the motor causes some vibration that cause the analog pin reading to fluctuate. I want the code to stop checking the analog pin when the condition is statified once.
int PressurePin = A1;
 delay(100);
 pressure=analogRead(PressurePin);
  Serial.print(pressure);
  if(pressure < 100)
 // rest ofthe code
Stop checking forever? Also does the motor continue to run forever?
Yes and the motor should continue to run.
 if(pressure < 100 && firstTime == true)
or
  while (pressure >= 100)
    delay(100);
    pressure = analogRead(PressurePin);
  // rest ofthe code
void loop() {}
alternatively, don't even do the analog read in the loop if the condition has been met:
if(!condition)
Thaks alot for the help. very much apreatiated!
