Hi all,
I am trying to make an LED turn on when the temperature reaches a certain temperature value but I am unsure where to add my modification lines of code inside the open source code for the exact same sensor I am using. I got the code for my digital sensor on THIS forum thread. HIs code is un commented for the most part and I am having difficulty following to some extent.
I converted his code to produce in celsius. The code and my addition to make an LED light at a temperature less than 26 degrees is shown below.
Can someone help me to get an LED to come on at less than 26 degrees please.
#include <OneWire.h>// http://playground.arduino.cc/Learning/OneWire (One Wire Libary)
#include <Wire.h>
OneWire ds(12); // on pin 12------------T1
int led = 7; // <<<<<<<<<<<<<<<<<< LED PIN
void setup(void)
ds.reset();
pinMode(led, OUTPUT); // <<<<<<<<<<<<<<<<<<< LED PinMode
unsigned int readBytes(int count)
unsigned int val = 0;
for (int i = 0; i < count; i++)
val |= (unsigned int)(ds.read() << i * 8);
return val;
void loop(void)
float temp1= Print_T1();
Serial.print(temp1);
Serial.print("\t");
if (temp1 <29 )// <<<<<<<<<<<<<<<<<<<<<<<<<<<< LED Temp condition
digitalWrite(led, LOW); // turn the LED on (HIGH is the voltage level)
float Print_T1()
byte temp_read = 0;
unsigned int count_remain = 0;
unsigned int count_per_c = 0;
byte configuration_register = 0;
ds.reset();
ds.write(0xEE); //Start Converting the temperatures
do {
delay(1);
ds.reset();
ds.write(0xAC);
// Read the configuration Register from the DS1821
configuration_register = readBytes(1);
} while ((configuration_register & (1 << 7)) == 0); // If Bit #8 is 1 then we are finished converting the temp
// Get Temp
ds.reset();
ds.write(0xAA);
temp_read = readBytes(1); ;
// Get Count Remaining
ds.reset();
ds.write(0xA0);
count_remain = readBytes(2);
// Load The Counter to populate the slope accumulator
ds.reset();
ds.write(0x41);
// Read Count Per Deg
ds.reset();
ds.write(0xA0);
count_per_c = readBytes(2);
// If we are reading above the 200 mark then we are below 0 and need to compensate the calculation
if (temp_read >= 200) temp_read -= 256;
float highResTemp = (float)temp_read - .5 + (((float)count_per_c - (float)count_remain) / (float)count_per_c);
if(highResTemp > 200)
highResTemp= highResTemp - 256.00;
return highResTemp;
