If USB and wall wart both plugged into Arduino, which one powers it?
I was told the Vref voltage is more stable when the Arduino is plugged in to a wall wart vs. the USB cable (I'm doing some very sensitive analog readings). However, I need to read serial data in so I need the USB cable plugged in. When both are plugged in, is there any chance the board defaults to the wall wart for power but sends data over USB? That would be ideal but I'm not sure how to confirm if that's happening.
No not necessarily.
Yes that is what will happen.
No not necessarily.
I posted about this on my blog, and someone commented as such:
http://www.dustynrobots.com/news/digital-signal-processing-and-filtering-motor-current-sensing/#comments
I haven't tested it yet though, in process.
Can I ask how you know this? I believe it, I'd just like to be able to troubleshoot better on my own in the future. I didn't see anything in the schematic that jumped out at me to say this would be so.
The stability of the Vref depends on the stability of the supply. What exactly are your concerns?
Well I did. It is a voltage comparator outputting into some FETs.
Got it. I'm trying to do current sensing on a robotic arm system through the analog in pins, and getting noisy output no matter what kind of RC filter I use. The blog commenter suggested that some of the noise could be from Vref itself, so I want to know how to minimize this if it exists (a well place capacitor?) or at least quantify the noise so I can more or less subtract it from the current signal.
Oh okay. Mechanical engineer here, still learning to make sense of the schematics.
given that:-
I would suggest you look at a better filter both for the motor and for the power supply.
A good read is:-
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
