If with lots of else if
How Can I create if statement with lots of else if (i need it to check ir signal)
send me code please. THANKS!
Really?
if (....) {
//repeat as many times as required
} else if (.....) {
} else (....) {
//final catch all else
(deleted)
pcbbc:
Really?
if (....) {
} else if (.....) {
} else (....) {
ok,so i'm making if then some else ifs and then last normal else?
imalfectyt:
It's a good idea to try the code that has been suggested before asking your next question.
If your program does not work as expected then post the program and tell us in detail what it actually does and what you want it to do that is different. Then we can focus on the parts you need help with rather than wasting time on things that you can do.
...R
it's all just a normal if/else statement
They are just nested, so in the first else, you happen to have a new if/else statement etc.
the last else is the else of the last if.
because they are nested you only reach the last else if everything else was evaluated to false
that's the typical if/else statement
if ([color=red]condition1[/color])
  [color=blue]statement1True[/color]
  [color=purple]statement1False[/color]
what you do is that
is actually again an if/else statement
if ([color=red]condition2[/color])
  [color=blue]statement2True[/color]
  [color=purple]statement2False[/color]
so you get
and then
is actually again an if/else statement.. rince and repeat ad nauseam
Look at any of the thousands of IR decode sketches out there, first of all the library examples. They will all have some kind of solution for this...
Robin2:
...R
sorry!
If your string of 'if/else' statements is comparing one integer variable against a list of integer constants, like this:
  if (integerVariableA == integerConstant1)
    // matches integerConstant1
  else if (integerVariableA == integerConstant2)
    // matches integerConstant2
  else if (integerVariableA == integerConstant3)
    // matches integerConstant3
  else if (integerVariableA == integerConstant4)
    // matches integerConstant4
  else if (integerVariableA == integerConstantN)
    // matches integerConstantN
    // final catch all else
You should use a 'switch/case' statement like this:
  switch (integerVariableA)
    case integerConstant1:
    case integerConstant2:
    case integerConstant3:
    case integerConstant4:
    case integerConstantN:
    default:
