if with multible conditions question?
My project has 2 valves and 3 pumps. I created the sketch, and uploaded it. But it is not working, all "OUTPUT" are "HIGH". Can you help?
This is my sketch:
#include <DS3231.h>
#include <Wire.h>
#include <LiquidCrystal.h>
DS3231 rtc(SDA, SCL);
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int x = 45;
int y = 47;
int z = 41;
int w = 43;
int WaterIn = 40;
int WaterOut = 42;
int Pump1 = 25;
int Pump2 = 24;
int Pump3 = 27;
rtc.begin();
lcd.begin(16,2);
// Start the I2C interface
Wire.begin();
// Start the serial interface
//rtc.setDOW(TUESDAY); // Set Day-of-Week to SUNDAY
//rtc.setTime(1, 15, 0); // Set the time to 12:00:00 (24hr format)
//rtc.setDate(6, 6, 2017); // Month, Day, Year
//Setup FLoat Switch Pins
pinMode (x, INPUT);
pinMode (y, INPUT);
pinMode (z, INPUT);
pinMode (w, INPUT);
//Setup Irrigation Valves
pinMode(WaterIn, OUTPUT); //irrigation "in" valve
pinMode(WaterOut, OUTPUT); //irrigation "out" valve
//Setup Pumps
pinMode(Pump1, OUTPUT);
pinMode(Pump2, OUTPUT);
pinMode(Pump3, OUTPUT);
} // end of setup
void Calendar(){
lcd.setCursor(0,0);
lcd.print("Real Time Clock ");
lcd.setCursor(0,1);
lcd.print("Time: ");
lcd.print(rtc.getTimeStr());
lcd.setCursor(0,1);
lcd.print("Date: ");
lcd.print(rtc.getDateStr());
lcd.setCursor(0,1);
lcd.print("Day: ");
lcd.print(rtc.getDOWStr());
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("Temp: ");
lcd.print(rtc.getTemp());
lcd.print(" C");
lcd.print(" ");
} // end of setup
void Valves(){
int pinToTurnHigh = 24;
if ((x == HIGH) && (y == HIGH) && (z == HIGH) && (w == LOW)) //Condition 1
pinToTurnHigh = WaterIn;
pinToTurnHigh = Pump1;
pinToTurnHigh = Pump2;
pinToTurnHigh = Pump3;
if ((x == LOW) && (y == LOW) && (z == HIGH) && (w == HIGH)) //Condition 2
pinToTurnHigh = WaterOut;
resetAllPumpValve();
digitalWrite(pinToTurnHigh, HIGH);
} // end of setup
void resetAllPumpValve(){
digitalWrite(WaterIn, LOW);
digitalWrite(Pump1, LOW);
digitalWrite(Pump2, LOW);
digitalWrite(Pump3, LOW);
digitalWrite(WaterOut, LOW);
} // end of setup
Calendar();
Valves();
} // end of loop
I'm a total novice, or at least not very good at making efficient code, but why wouldn't you just digitalWrite your pumps and valves HIGH instead of using "pinToTurnHigh"?
digitalRead(...) will help
Assigning 4 different values to one variable is rather pointless. It can only hold one value at a time.
And, the pin number (x, y, z, and w) (dumb names, by the way) and the pin state are NOT the same thing.
From the replies so far, it may be worth taking those observations and starting again...
When you re-post, use CTRL-T in the IDE before you cut the code and paste into the block.
