pert:
The problem is not completely clear to me. Ideally you could provide a MCVE but posting the full code would work.
ok, here´s the big one
I will not add also all libary files if not absolutely needed ^^
Led_Basesketch_w_MySen_by_Inso.ino
Created: 07.11.2018 22:39:08
Author: INSO-MAINFRAME\Inso
Created: 02.11.2018 10:26:06
Author: Inso
config your stripes within config.h
#include "config.h"
#include "FastLED_Functions_by_Inso.h"
#include "arduino.h"
#ifdef MYSEN
#include <MySensors.h>
#endif
#ifdef DEBUGMEM
#include <MemoryFree.h>
#endif
CRGB ledsS1[NUM_LEDS_S1];
FastLED_Functions_by_Inso S1(NUM_LEDS_S1, DATA_PIN_S1, ledsS1, 1);
#ifdef NUM_LEDS_S2
CRGB ledsS2[NUM_LEDS_S2];
FastLED_Functions_by_Inso S2(NUM_LEDS_S2, DATA_PIN_S2, ledsS2, 2);
#endif
#ifdef NUM_LEDS_S3
CRGB ledsS3[NUM_LEDS_S3];
FastLED_Functions_by_Inso S3(NUM_LEDS_S3, DATA_PIN_S3, ledsS3, 3);
#endif
#ifdef NUM_LEDS_S4
CRGB ledsS4[NUM_LEDS_S4];
FastLED_Functions_by_Inso S4(NUM_LEDS_S4, DATA_PIN_S4, ledsS4, 4);
#endif
#ifdef NUM_LEDS_S5
CRGB ledsS5[NUM_LEDS_S5];
FastLED_Functions_by_Inso S5(NUM_LEDS_S5, DATA_PIN_S5, ledsS5, 5);
#endif
// Arraycreation
#if STRIPE_AMOUNT == 1
FastLED_Functions_by_Inso* overallArray[] = { &S1 };
#elif STRIPE_AMOUNT == 2
FastLED_Functions_by_Inso* overallArray[] = { &S1, &S2 };
#elif STRIPE_AMOUNT == 3
FastLED_Functions_by_Inso* overallArray[] = { &S1, &S2, &S3 };
#elif STRIPE_AMOUNT == 4
FastLED_Functions_by_Inso* overallArray[] = { &S1, &S2, &S3, &S4 };
#elif STRIPE_AMOUNT == 5
FastLED_Functions_by_Inso* overallArray[] = { &S1, &S2, &S3, &S4, &S5 };
#endif
FastLED_Functions_by_Inso All(overallArray);
// TextChild
#ifdef MYSEN
char textString[26] = ""; // String mit 25 Zeichen plus /n für erhaltenen Text (max 25 Zeichen möglich wg Übertragungslimit)
#endif
int programMode;
// Initialize messages for sensor network
#ifdef MYSEN
MyMessage dimmerMsg(DIMMER_CHILD, V_DIMMER);
MyMessage lightMsg(DIMMER_CHILD, V_LIGHT);
MyMessage textMsg(TEXT_CHILD, V_TEXT);
MyMessage msgBin(BINARY_CHILD, V_STATUS);
#endif
#ifdef DEBUG
Serial.println("begin of setup");
#endif
FastLED.addLeds<WS2812B, DATA_PIN_S1, GRB>(ledsS1, NUM_LEDS_S1);
fill_solid(ledsS1, NUM_LEDS_S1, CRGB(0, 0, 0));
#ifdef NUM_LEDS_S2
FastLED.addLeds<WS2812B, DATA_PIN_S2, GRB>(ledsS2, NUM_LEDS_S2);
fill_solid(ledsS2, NUM_LEDS_S2, CRGB(0, 0, 0));
#endif
#ifdef NUM_LEDS_S3
FastLED.addLeds<WS2812B, DATA_PIN_S3, GRB>(ledsS3, NUM_LEDS_S3);
fill_solid(ledsS3, NUM_LEDS_S3, CRGB(0, 0, 0));
#endif
#ifdef NUM_LEDS_S4
FastLED.addLeds<WS2812B, DATA_PIN_S4, GRB>(ledsS4, NUM_LEDS_S4);
fill_solid(ledsS4, NUM_LEDS_S4, CRGB(0, 0, 0));
#endif
#ifdef NUM_LEDS_S5
FastLED.addLeds<WS2812B, DATA_PIN_S5, GRB>(ledsS5, NUM_LEDS_S5);
fill_solid(ledsS5, NUM_LEDS_S5, CRGB(0, 0, 0));
#endif
FastLED.setBrightness(255);
FastLED.show();
#ifdef DEBUG
Serial.println("end of setup");
#endif
#ifdef MYSEN
request(DIMMER_CHILD, V_PERCENTAGE, 0);
#endif
All.setColor(0, 0, 0);
All.ledsOn();
#ifdef MYSEN
void presentation()
// Register the LED Dimmable Light with the gateway
// LED01
present(DIMMER_CHILD, S_DIMMER, "Dimmer" NODE_TXT);
present(RGB_CHILD, S_RGB_LIGHT, "RGB Light" NODE_TXT);
present(TEXT_CHILD, S_INFO, "Text Child" NODE_TXT);
present(BINARY_CHILD, S_BINARY, "Security Byte" NODE_TXT);
sendSketchInfo(SKETCH_INFO_TEXT);
#endif
#ifdef DEBUG
Serial.println("--------------------------------");
Serial.println("loop begin");
#endif
#ifdef DEBUGMEM
Serial.print("freeMemory()=");
Serial.println(freeMemory());
#endif
All.setColor(0, 0, 1);
All.ledsOnSecondBlack();
All.setColor(0, 0, 255);
All.dimFromToByColor(0, 255, 1, 0, 255, 1, 0, 255, 1, 0, 255, 1, 0, 255, 1, 0);
All.setColor(255, 0, 0);
All.ledsOffOneByOne();
//All.ledsOff();
#ifdef DEBUG
Serial.println("loop end");
Serial.println("");
#endif
//FastLED_Functions_by_Inso::LedsAn();
//Funktionen::LedsAn();
#ifdef MYSEN
void receive(const MyMessage &message) // Wird immer ausgeführt wenn ein Wert empfangen wird, egal ob vom Dimmer, angeforderter Text oder simples on/off
byte redVal;
byte greenVal;
byte blueVal;
byte brightVal;
byte modeToStart;
int data;
if (message.sensor == DIMMER_CHILD) { // später Dimmer konfigurieren
// Aufbau Message: pm,red,grn,blu,bri,md,data
else if (message.sensor == TEXT_CHILD) {
snprintf(textString, sizeof(textString), "%16s", message.getString()); //gesendeter Text / Wert wird an einen String übergeben
programMode = atoi(strtok(textString, ",")); //Funktion um übergebenen Kommawert aufzusplitten in drei Integer. atoi macht String to int ; strtok splittet. String wird dabei umgeschrieben!
redVal = atoi(strtok(NULL, ","));
greenVal = atoi(strtok(NULL, ","));
blueVal = atoi(strtok(NULL, ","));
brightVal = atoi(strtok(NULL, ","));
modeToStart = atoi(strtok(NULL, ","));
data = atoi(strtok(NULL, ","));
// programMode definiert den Modus ODER sagt welche LEDs angesprochen werden. umrechnung zu binary
boolean allS = 0;
boolean s1 = 0;
boolean s2 = 0;
boolean s3 = 0;
boolean s4 = 0;
boolean s5 = 0;
if (programMode < 31) // 30 ist binär unter 11111, sprich min eine Stripe wird nicht angesprochen. 1000 ist Stripe 1 usw..
byte num = programMode + 32; // 32 ist b100000, sprich die führende eins so das nullen danach nicht verschöuckt würden
char bitString[6] = { 0 }; // CharArray für folge an bits
itoa(num, bitString, 2); // byte to bit
if (bitString[0] == '1')
S1.setColor(redVal, greenVal, blueVal);
boolean s1 = 1;
#ifdef NUM_LEDS_S2
if (bitString[1] == '1')
S2.setColor(redVal, greenVal, blueVal);
boolean s2 = 1;
#endif
#ifdef NUM_LEDS_S3
if (bitString[2] == '1')
S3.setColor(redVal, greenVal, blueVal);
boolean s3 = 1;
#endif
#ifdef NUM_LEDS_S4
if (bitString[3] == '1')
S4.setColor(redVal, greenVal, blueVal);
boolean s4 = 1;
#endif
#ifdef NUM_LEDS_S5
if (bitString[4] == '1')
S5.setColor(redVal, greenVal, blueVal);
boolean s5 = 1;
#endif
else if (programMode == 31) // 31 ist binär 11111
All.setColor(redVal, greenVal, blueVal);
boolean allS = 0;
else if (programMode > 31)
if (programMode <= 31)
if (modeToStart == 0) { All.ledsOff(s1, s2, s3, s4, s5);}
if (modeToStart == 1) { All.ledsOn(s1, s2, s3, s4, s5);}
if (modeToStart == 2) { All.ledsOnSecondBlack(s1, s2, s3, s4, s5);}
if (modeToStart == 3) { All.ledsOnOneByOne(s1, s2, s3, s4, s5, data); }
if (modeToStart == 4) { All.ledsOffOneByOne(s1, s2, s3, s4, s5, data); }
if (modeToStart == 5) { All.dimFromToByColor(0, 255, s1, 0, 255, s2, 0, 255, s3, 0, 255, s4, 0, 255, s5, 1); }
// dim only every second (last 0)
if (modeToStart == 6) { All.dimFromToByColor(0, 255, s1, 0, 255, s2, 0, 255, s3, 0, 255, s4, 0, 255, s5, 0); }
Serial.println("Message received");
#endif
