iframe question on ethernet board
Im learning on Zoomkats iframe code, i made a 4 link slowdata so if i
click on it the data should refresh every 10 seconds but when i click on it
it takes refresh time 0 from fastdata, can someone help me with this ?
see code below
Greetings and thanks
#include <Arduino.h>
#define Echo_ingangsPin 7 // ingang echo pin
#define Trigger_uitgangsPin 8 // trigger uitgangspin
int maximumRange = 300;
int minimumRange = 2;
// zoomkat's meta refresh data frame test page 5/25/13
// use http://192.168.1.102:84 in your brouser for main page
// http://192.168.1.102:84/data static data page
// http://192.168.1.102:84/datastart meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
#include <Ethernet2.h>
long afstand;
long duur;
const int analogInPin0 = A0;
const int analogInPin1 = A1;
const int analogInPin2 = A2;
const int analogInPin3 = A3;
const int analogInPin4 = A4;
const int analogInPin5 = A5;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0xB4, 0x00}; //physical mac address
byte ip[] = { 10, 33, 211, 179}; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
  pinMode(Trigger_uitgangsPin, OUTPUT);
  pinMode(Echo_ingangsPin, INPUT);
    // disable SD SPI if memory card in the uSD slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println("meta refresh data frame test 5/25/13"); // so I can keep track of what is loaded
void loop(){
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
         if (readString.length() < 100) {
          readString += c;
        //check if HTTP request has ended
        if (c == '\n') {
          //check get atring received
          Serial.println(readString);
          //output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          //generate data page
          if(readString.indexOf("data") >0) {  //checks for "data" page
            x=x+1; //page upload counter
            client.print("<HTML><HEAD>");
            //meta-refresh page every 1 seconds if "datastart" page
            if(readString.indexOf("datastart") >0) client.print("<meta http-equiv='refresh' content='1'>");
            //meta-refresh 0 for fast data
            if(readString.indexOf("datafast") >0) client.print("<meta http-equiv='refresh' content='0'>");
            //meta-refresh 10 for slowdata
            if(readString.indexOf("slowdata") >0) client.print("<meta http-equiv='refresh' content='10'>");
            client.print("<title>Zoomkat's meta-refresh test</title></head><BODY>
            client.print("page refresh number: ");
            client.print(x); //current refresh count
            client.print("
            // nieuw stuk
            // pulse van 10µs die word gestuurd
            digitalWrite(Trigger_uitgangsPin, HIGH);
            delayMicroseconds(10);
            digitalWrite(Trigger_uitgangsPin, LOW);
            duur = pulseIn(Echo_ingangsPin, HIGH);
            afstand = duur/58.2;
              //output the value of each analog input pin
            if (afstand >= maximumRange || afstand <= minimumRange);
            client.print("afstand: ");
            client.print(afstand);
            client.print("
analog input0 is: ");
            client.print(analogRead(analogInPin0));
            client.print("
analog input1 is: ");
            client.print(analogRead(analogInPin1));
            client.print("
analog input2 is: ");
            client.print(analogRead(analogInPin2));
            client.print("
analog input3 is: ");
            client.print(analogRead(analogInPin3));
            client.print("
analog input4 is: ");
            client.print(analogRead(analogInPin4));
            client.print("
analog input5 is: ");
            client.print(analogRead(analogInPin5));
            client.println("
</BODY></HTML>");
          //generate main page with iframe
            client.print("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>");
            client.print("Zoomkat's Arduino frame meta refresh test 5/25/13");
            client.print("
Arduino analog input data frame:
            client.print("&nbsp;&nbsp;<a href='/datastart' target='DataBox' title=''aa''>META-REFRESH</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='/data' target='DataBox' title=''bb''>SINGLE-STOP</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='/datafast' target='DataBox' title=''cc''>FAST-DATA</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='/datafaster' target='DataBox' title=''dd''>SLOW-DATA</a>
            client.print("<iframe src='/data' width='350' height='500' name='DataBox'>");
            client.print("</iframe>
</HTML>");
          delay(100);
          //stopping client
          client.stop();
          //clearing string for next read
          readString="";
Have you tried printing readString when you discover that c equals '\n'? I'm willing to bet that a clue-by-four whacks you when you do.
