Igbt charge regulator
good morning everyone, I am creating a charge controller that must be powered by a 12v battery which must then be charged by a 24v 250w solar panel where the current is regulated with a K75T60 IGBT, but since this conducts in only one direction, it does not I can understand where on the panel mesh I can put it to interrupt the current going to the battery. I'm attaching a photo which definitely doesn't work because the current should run in the other direction. Please help me I can't find a solution
I think you should stop this project.
There is a serious danger of fire.
You seem not at all able to do this project.
It is a difficult project.
Buy a module...
Second that. You are going to hurt yourself - and most likely set fire on your facility, 'cause I have the gutt feeling you plan on using some LiPo cells.
The electrical connections in your image are likely to cause a fire. Repeating lithium issues now will.
Do not fry yourself. You can get a Solar charge controller for probably less then the cost of the parts you are mentioning.
