Ignition simulation with canbus
Hi can any one help me please I’m having trouble getting this to work I want it to switch the relay on when it receives the canbus id and data and off when it no longer receives the canbus id and data, this is to simulate an ignition live so I can power up/down a DVD multi media system I have put in my car for my kids, if I leave it plugged in the battery will go flat and that’s not good when we are out, and help would be much appreciated thanks
#include <SPI.h>
#include “mcp_can.h”
#define INT32U unsigned long int
INT32U canId = 0x00;
unsigned char len = 0;
unsigned char buf[8];
char str[20];
String CanMessage="";
int IgnitionDetected=0;
int RelayCHN01=4;
const int SPI_CS_PIN = 17;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
//INIT RELAY PIN
pinMode(RelayCHN01, OUTPUT);
//TEST RELAY PIN
TESTRElay();
START_INIT:
if(CAN_OK == CAN.begin(CAN_125KBPS))
Serial.println(“CAN BUS Shield init ok!”);
Serial.println(“CAN BUS Shield init fail”);
Serial.println(“Init CAN BUS Shield again”);
delay(100);
//goto START_INIT;
if(CAN_MSGAVAIL == CAN.checkReceive())
CAN.readMsgBuf(&len, buf);
CanMessage="";
canId = CAN.getCanId();
//Detect Ignition
if (canId==0x0048)
//Build Complete Message Without CAN ID From BUS
for(int i = 0; i<len; i++) // print the data
CanMessage = CanMessage + buf*;*
  • if (CanMessage==“0XFF, 0x07, 0x6C, 0x09, 0x27, 0x02, 0xE0”){IgnitionDetected=1;}else{IgnitionDetected=0;}*
  • if (IgnitionDetected==1)*
  • //PUT CODE HERE To TURN ON Relay*
  • Serial.println(“Relay turned on!!!”);*
  • digitalWrite(RelayCHN01, HIGH);*
  • else*
  • digitalWrite(RelayCHN01, LOW);*
    void TESTRElay()
    delay(200);
    delay(200);
    delay(200);
    delay(200);
why do you need such complication when you have many power lines that are only ON when you turn the car key? the one that powers the car radio for instance...
Hi there all canbus controlled
what vehicle is this in exactly?
I understand your issue and there is an easier way of doing it.
Gwe89: Hi there all canbus controlled
I'd be looking at the schematic of your vehicle, even the ignition switch has to turn power ON, not necessarily make a CANBUS commmand.
Look at the operation of your fuse boxe(s). They will have fuses that are only supplied with power while the vehicle has its igntion/accessories ON. Tom... :)
Go to Crutchfield and enter your vehicle information. They most likely sell a premade radio wiring harness for that car that has everything you need.
cedarlakeinstruments:
and that’s where I was going as well.
