I'm trying to get my sketch to trigger a MIDI note when my analog data passes a certain threshold.
Right now it repeats the midi note super fast, so long as the data is above the threshold. I don't want it to repeat at all, I only want the note to play once. I would like my sketch to ignore repetitions until the data passes under the threshold again.
Basically I want to do what the [change] object does in Max/MSP, if anyone's familiar. I will need to store the "state" of the sensor and compare it against new data to see if it has changed.
If that code is in your main loop you will need someway of "remembering" that it has already been executed. I think something like this would work, although it feels sloppy.
Here's what I'm trying now, which is kind of an improvement:
data1 = analogRead(0); // read the sensor data
if (data1 < loThresh1 || data1 > hiThresh1){ // determine if data is above or below threshold
state1 = 1; // 1 if sensor is being tripped
else {
state1 = 0; // 0 if sensor is not being tripped
if (state1 - lastState1 == 1){ // will yield 1 for a change from off to on (1 minus 0)
noteOn(0x90, handClap, 127); // play the note
lastState1 = state1; // remember last sensor state
However it's still repeating the note, but not nearly as fast. Maybe it's an issue of my analog data bouncing under/over the threshold?
Yeah that is a common threshold problem in electronics, what happens is as you cross the threshold you get rapid switching between the off and on state, one way to deal with this is to create a buffer, as in the tone will start one it passes out of threshold but it will not start again until it passes a few notches below the threshold. Those notches create a buffer.
What Justin means is that:-
If the note is playing the threshold to turn it off is say 512
If the note is NOT playing the threshold to turn it on is say 600
It's a different threshold when going up to going down, I call this hysteresis.
