Hello @all ![]()
I´m monkey a fully nerd in Arduino ![]()
I have now this Project started but i have very very probs that run's.
The Sketch is NOT from me that have a other user writing.I become no errors while compiling but on the Mega2560 do nothing. No menu no Led ..... working. Can anybody help me that the project run´s ?
Lg monkey
...here.
Why not?
Your post was MOVED to its current location as it is more suitable.
Klaas De Craemer, Ing. David Hrbaty he have writing the programm ![]()
How can i upload the sketch ?
TEST.ino (7.7 KB)
By clicking on the '</>' button above on the toolbar, and pasting the code between the code tags it gives you.
Ok THX
No, the control marked '</>', just to the right of the " control.
Sixth from the left.
/* LedTable
* Written by: Klaas De Craemer, Ing. David Hrbaty, Modified by: Mark Quinn
* Main file with common methods and defines, such as button reading from Bluetooth controller
* or setting pixels on the LED area
#include <SoftwareSerial.h>
//LED field size
#define FIELD_WIDTH 16
#define FIELD_HEIGHT 16
const int NUM_LEDS=FIELD_WIDTH*FIELD_HEIGHT;
#define ORIENTATION_HORIZONTAL //Rotation of table, uncomment to rotate field 90 degrees
#include <SPI.h>
#include <SD.h>
#define USE_FAST_LED // FAST_LED as library to control the LED strips
#define BLUETOOTH_SPEED 38400
* Some defines used by the FAST_LED library
#define FAST_LED_CHIPSET WS2812B
#define FAST_LED_DATA_PIN 2
#define MAX_BRIGHTNESS 255 // Thats full on, watch the power!
#define MIN_BRIGHTNESS 10 // set to a minimum of 8%
const int brightnessInPin = A0;
#define NUM_PIXELS FIELD_WIDTH*FIELD_HEIGHT
/* *** LED color table *** */
#define GREEN 0x008000
#define RED 0xFF0000
#define BLUE 0x0000FF
#define YELLOW 0xFFFF00
#define LBLUE 0x00FFFF
#define PURPLE 0xFF00FF
#define WHITE 0XFFFFFF
#define AQUA 0x00FFFF
#define HOTPINK 0xFF69B4
unsigned int long colorLib[9] = {RED, GREEN, BLUE, YELLOW, LBLUE, PURPLE, WHITE, AQUA, HOTPINK};
/* *** Game commonly used defines ** */
#define DIR_UP 1
#define DIR_DOWN 2
#define DIR_LEFT 3
#define DIR_RIGHT 4
/* *** Bluetooth controller button defines and input method *** */
#define BTN_NONE 0
#define BTN_UP 1
#define BTN_DOWN 2
#define BTN_LEFT 3
#define BTN_RIGHT 4
#define BTN_START 5
#define BTN_EXIT 6
uint8_t curControl = BTN_NONE;
// Serial1.begin(9600);
byte incomingByte;
void readInput()
if (Serial1.available() > 0)
// read the incoming byte:
incomingByte = Serial1.read();
Serial.println(incomingByte);
switch(incomingByte)
case 51: curControl = BTN_LEFT; break;
case 52: curControl = BTN_RIGHT; break;
case 49: curControl = BTN_UP; break;
case 50: curControl = BTN_DOWN; break;
case 53: curControl = BTN_START; break;
case 54: curControl = BTN_EXIT; break;
* FAST_LED implementation
#ifdef USE_FAST_LED
#include "FastLED.h"
#endif
CRGB leds[NUM_PIXELS];
void initPixels(){
FastLED.addLeds<FAST_LED_CHIPSET, FAST_LED_DATA_PIN, RGB>(leds, NUM_PIXELS);
void setPixel(int n, int long color){
leds[n] = CRGB(color);
void setPixelRGB(int n, int long r,int long g, int long b){
leds[n] = CRGB(r,g,b);
void setDelay(int duration) {
FastLED.delay(duration);
int getPixel(int n){
return (leds[n].r << 16) + (leds[n].g << 8) + leds[n].b;
void showPixels(){
int mappedValue = map(analogRead(brightnessInPin), 0, 1023, 0, MAX_BRIGHTNESS);
FastLED.setBrightness(constrain(mappedValue, MIN_BRIGHTNESS, MAX_BRIGHTNESS));
FastLED.show();
void setTablePixel(int x, int y, int long color){
#ifdef ORIENTATION_HORIZONTAL
x=FIELD_HEIGHT-x;
setPixel(y%2 ? y*FIELD_WIDTH + x : y*FIELD_WIDTH + ((FIELD_HEIGHT-1)-x),color);
#ifdef USE_CONSOLE_OUTPUT
setTablePixelConsole(y,x,color);
#endif
#else
x=FIELD_WIDTH-x;
setPixel(x%2 ? x*FIELD_WIDTH + ((FIELD_HEIGHT-1)-y) : x*FIELD_WIDTH + y,color);
setTablePixelConsole(x,y,color);
#endif
#endif
void setTablePixelRGB(int x, int y, int long r,int long g, int long b){
setPixelRGB(y%2 ? y*FIELD_WIDTH + x : y*FIELD_WIDTH + ((FIELD_HEIGHT-1)-x),r,g,b);
#endif
#else
setPixelRGB(x%2 ? x*FIELD_WIDTH + ((FIELD_HEIGHT-1)-y) : x*FIELD_WIDTH + y,r,g,b);
#endif
#endif
void clearTablePixels(){
for (int n=0; n<FIELD_WIDTH*FIELD_HEIGHT; n++){
setPixel(n,0);
/* *** text helper methods *** */
#include "font.h"
uint8_t charBuffer[8][8];
void printText(char* text, unsigned int textLength, int xoffset, int yoffset, int long color){
uint8_t curLetterWidth = 0;
int curX = xoffset;
clearTablePixels();
//Loop over all the letters in the string
for (int i=0; i<textLength; i++){
//Determine width of current letter and load its pixels in a buffer
curLetterWidth = loadCharInBuffer(text[i]);
//Loop until width of letter is reached
for (int lx=0; lx<curLetterWidth; lx++){
//Now copy column per column to field (as long as within the field
if (curX>=FIELD_WIDTH){//If we are to far to the right, stop loop entirely
} else if (curX>=0){//Draw pixels as soon as we are "inside" the drawing area
for (int ly=0; ly<8; ly++){//Finally copy column
setTablePixel(curX,yoffset+ly,charBuffer[lx][ly]*color);
curX++;
showPixels();
//Load char in buffer and return width in pixels
uint8_t loadCharInBuffer(char letter){
uint8_t* tmpCharPix;
uint8_t tmpCharWidth;
int letterIdx = (letter-32)*8;
int x=0; int y=0;
for (int idx=letterIdx; idx<letterIdx+8; idx++){
for (int x=0; x<8; x++){
charBuffer[x][y] = ((font[idx]) & (1<<(7-x)))>0;
y++;
tmpCharWidth = 8;
return tmpCharWidth;
void fadeOut(){
//Select random fadeout animation
int selection = random(3);
switch(selection){
case 0:
case 1:
//Fade out by dimming all pixels
for (int i=0; i<100; i++){
dimLeds(0.97);
showPixels();
delay(10);
case 2:
//Fade out by swiping from left to right with ruler
const int ColumnDelay = 10;
int curColumn = 0;
for (int i=0; i<FIELD_WIDTH*ColumnDelay; i++){
dimLeds(0.97);
if (i%ColumnDelay==0){
//Draw vertical line
for (int y=0;y<FIELD_HEIGHT;y++){
setTablePixel(curColumn, y, GREEN);
curColumn++;
showPixels();
delay(5);
//Sweep complete, keep dimming leds for short time
dimLeds(0.9);
showPixels();
delay(5);
void dimLeds(float factor){
//Reduce brightness of all LEDs, typical factor is 0.97
for (int n=0; n<(FIELD_WIDTH*FIELD_HEIGHT); n++){
int curColor = getPixel(n);
//Derive the tree colors
int r = ((curColor & 0xFF0000)>>16);
int g = ((curColor & 0x00FF00)>>8);
int b = (curColor & 0x0000FF);
//Reduce brightness
r = r*factor;
g = g*factor;
b = b*factor;
//Pack into single variable again
curColor = (r<<16) + (g<<8) + b;
//Set led again
setPixel(n,curColor);
void setup(){
//Wait for serial port to connect
Serial1.begin(BLUETOOTH_SPEED);
//Initialise display
initPixels();
showPixels();
//Init random number generator
randomSeed(analogRead(5)/millis());
pinMode(4, OUTPUT); // CS/SS pin as output for SD library to work.
digitalWrite(4, HIGH); // workaround for sdcard failed error...
if (!SD.begin(4))
Serial.println("sdcard initialization failed!");
return;
Serial.println("sdcard initialization done.");
mainLoop();
void loop(){
OK THANK ![]()
the whole sketch uses more files if you want I can upload it via zip fileLED TABLE MONKEY.zip (26.7 KB)
I hope you can Help me ![]()
i dont understand why nothing runs
Did you build it bit-by-bit, testing as you went along, or just put it all together and expected it to work?
No, according to the description, it is only for compiling and uploading. I did what had to be changed. For the SD card I had to change the pins so that it could be read, that's the only thing I got to work
What does that mean?
I dont no what do you mean ? The Code must be worked ;(
...for proven working hardware. (?)
Also the Programm is for a Mega 2560 while the size of code is too big for an Uno ![]()
Hardware: Arduino Mega 2560
Bluetooth Modul HC05 or HC06
A SD-CARD Shield and
WS2812B Neopixel LED
Presumably, you have all that hardware, and you have proved them all to work independently, yes?
SORRY !!!!! Unfortunately, I don't know what exactly you mean by processed?
do I have to test everything separately? if yes how ? Basically I have to upload the main code and it should work
Ok I understand
do you mean i make sketch by sketch to upload ?
can you help me please ?
I can no more messages at on my first day say the forum !!!!!!!!!!!!!
I haven't mentioned the word "processed".
Where did that come from?
Yes, if you're building a system comprising more than one component, you test each element, before moving on to the next.
