IL9486 TFT touch buttons events and parameters
EDIT: included again the code formatted correctly (I hope)
I made a new sketch, just to learn, using the MCUFRIEND:kbv/button_list as starting point.
The goal is to draw 10 buttons arranged like a keypad.
This is running fine, but I'd like to change the backcolor (and possibly the text color) when a button is pressed. I was able to retry the button index and print it on the Serial.
I can not find a method to flip the colors; I made some tries (one you'll see in the Loop), but I think that the button constructor has not something like a 'Fill' method in the libraries. In other words, I do not know how to access the button's parameters.
Second question: when I push a button I get a 'Pressed' and 'JustPressed' events, but they repeat until the push is realesed; I thought that the JustPresses event is raised just once, to avoid the color flashing (if I'm able to change it).
This is my code:
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
const int XP = 6, XM = A2, YP = A1, YM = 7;  //ID=0x9341
const int TS_LEFT = 928, TS_RT = 182, TS_TOP = 962, TS_BOT = 180;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
MCUFRIEND_kbv tft;
Adafruit_GFX_Button btn0, btn1, btn2, btn3, btn4, btn5, btn6, btn7, btn8, btn9;
int pixel_x, pixel_y;  //Touch_getXY() updates global vars
bool Touch_getXY(void) {
  TSPoint p = ts.getPoint();
  pinMode(YP, OUTPUT);  //restore shared pins
  pinMode(XM, OUTPUT);
  digitalWrite(YP, HIGH);  //because TFT control pins
  digitalWrite(XM, HIGH);
  bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
  if (pressed) {
    pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width());  //.kbv makes sense to me
    pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
  return pressed;
  uint16_t ID = tft.readID();
  if (ID == 0xD3D3) ID = 0x9486;  // write-only shield
  tft.begin(ID);
  tft.setRotation(0);  //PORTRAIT
  tft.fillScreen(BLACK);
  btn0.initButton(&tft, 150, 350, 80, 40, WHITE, CYAN, BLACK, "0", 2);
  btn1.initButton(&tft, 60, 200, 80, 40, WHITE, CYAN, BLACK, "1", 2);
  btn2.initButton(&tft, 150, 200, 80, 40, WHITE, CYAN, BLACK, "2", 2);
  btn3.initButton(&tft, 240, 200, 80, 40, WHITE, CYAN, BLACK, "3", 2);
  btn4.initButton(&tft, 60, 250, 80, 40, WHITE, CYAN, BLACK, "4", 2);
  btn5.initButton(&tft, 150, 250, 80, 40, WHITE, CYAN, BLACK, "5", 2);
  btn6.initButton(&tft, 240, 250, 80, 40, WHITE, CYAN, BLACK, "6", 2);
  btn7.initButton(&tft, 60, 300, 80, 40, WHITE, CYAN, BLACK, "7", 2);
  btn8.initButton(&tft, 150, 300, 80, 40, WHITE, CYAN, BLACK, "8", 2);
  btn9.initButton(&tft, 240, 300, 80, 40, WHITE, CYAN, BLACK, "9", 2);
  btn0.drawButton(false);
  btn1.drawButton(false);
  btn2.drawButton(false);
  btn3.drawButton(false);
  btn4.drawButton(false);
  btn5.drawButton(false);
  btn6.drawButton(false);
  btn7.drawButton(false);
  btn8.drawButton(false);
  btn9.drawButton(false);
// Array of button addresses to behave like a list
Adafruit_GFX_Button *buttons[] = { &btn0, &btn1, &btn2, &btn3, &btn4, &btn5, &btn6, &btn7, &btn8, &btn9, NULL };
bool update_button(Adafruit_GFX_Button *b, bool down) {
  b->press(down && b->contains(pixel_x, pixel_y));
  if (b->justReleased()) {
    b->drawButton(false);
  if (b->justPressed()) {
    b->drawButton(true);
  return down;
bool update_button_list(Adafruit_GFX_Button **pb) {
  bool down = Touch_getXY();
  for (int i = 0; pb[i] != NULL; i++) {
    update_button(pb[i], down);
  return down;
  update_button_list(buttons);  //use helper function
  for (int i = 0; buttons[i] != NULL; i++) {
    if (buttons[i]->isPressed()) {
      Serial.print("Btn ");
      Serial.println(i);
      buttons[i]->drawButton(true);
//      buttons[i].fill(RED); // <=== here I want to flip color
    if (buttons[i]->justReleased()) {
      buttons[i]->drawButton(false);
Thanks as always
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
Why the > sign starting every line?
Surely there is a fill function for the display. Check the library again!
Sorry for my error, and thanks. I'm still quite confused with the categories
Does the library give you access to the colors that you set in the initializer? If so then you should just be able to change it in your update function along with the text color. If the library doesn't allow this, then you are free to change the library assuming its not password protected by the original author.
Either make each color public or give yourself a function to set all 3 or individually if need be.
