I have ILI 9341 Touch LCD 2.8'' with SDCard. I am running the example:
tutorial
I connected Mega with Ili like this: diagram
I connected SD Card on my LCD to the project using the same pins and connections that I used for LCD, so for example CS and SD_CS are on pin 53.
Program starts and tries to refresh the screen there are two problems:
- The program says that there is no such file on the card, however listing all files shows something else..
- When I insert SD card Utouch library for handling the touch events always returns point 0,319, when I remove sc card, utouch work better and I am able to navigate my menu.
Initialising SD card...225term.bmp225term.raw225termi.bmp240Moon.bmp240Moon.raw284taz.bmp284taz.raw480Mouse.bmpInst_1.bmpInst_1.rawtest_dn.bmptest_up.bmptest_up.rawtest_ups.bmptest_ups.rawTiger.bmpTiger.rawHere we go...
File not found
0
299
File not found
File not found
0
File not found
File not found
Below is the sketch:
#include <Adafruit_GFX_AS.h> // Core graphics library
#include <Adafruit_ILI9341_AS.h> // Hardware-specific library
//#include <SD.h> // SD card library a bit slower and bigeger than SdFat
#include <SdFat.h> // More compact and faster than SD
SdFat SD; // For SD compatibility
#include <SPI.h> // SPI libray obviously!
String sdata="";
SdFile file;
// These are the pins I use on an UNO, may need chaging for your setup
// Use hardware SPI lines
#define _sclk 52
#define _miso 50 // Needed for SD card, but does not need to be connected to TFT
#define _mosi 51 // Master Out Slave In to send commands/data to TFT and SD card
// TFT chip select and data/command line
#define _cs 53
#define _dc 49
// SD chip select
#define _sdcs 53
// TFT reset line, can be connected to Arduino reset
#define _rst 48
Adafruit_ILI9341_AS tft = Adafruit_ILI9341_AS(_cs, _dc, _rst); // Invoke custom library
// You can use MS Paint to pick colours off an image and see the RGB values
// This colour is off the mouse image.
#define ILI9341_GREY 0xCE9A // Light grey
// These are used when calling drawBMP() function, see examples in loop()
#define BU_BMP 1 // Temporarily flip the TFT coords for standard Bottom-Up bit maps
#define TD_BMP 0 // Draw inverted Top-Down bitmaps in standard coord frame
uint32_t drawTime = 0; // Variable to save draw times for testing
Serial.begin(9600); // For debug messages
/********************* Add these Two Lines **********************/
pinMode(10, OUTPUT); // change this to 53 on a mega // don't follow this!!
digitalWrite(10, HIGH); // Add this line
Serial.print(F("Initialising SD card..."));
if (!SD.begin(_sdcs, SPI_FULL_SPEED)) { // sdFat library allows speed setting, e.g. SPI_HALF_SPEED
//if (!SD.begin(_sdcs)) { // Only needed when standard SD library is used
Serial.println(F("failed!"));
//return;
while (file.openNext(SD.vwd(), O_READ)) {
file.printName(&Serial);
file.close();
tft.init(); // Initialise the display (various parameters configured)
Serial.println(F("Here we go..."));
Serial.println(sdata);
// Set text foreground and background colours
tft.setTextColor(ILI9341_BLACK, ILI9341_WHITE);
tft.setRotation(1);
tft.fillScreen(ILI9341_GREY);
// Draws raw image with top left corner pixel at x,y = 0,0
drawRAW("Inst_1.raw", 0, 0, 320, 240);
// Using a bmp will be 50% slower and draws from bottom up
//drawBMP("Inst_1.bmp", 0, 0, BU_BMP);
// Show draw time (time measuring lines can be commented out in function if not needed)
int xpos = 0;
xpos += tft.drawNumber(drawTime, xpos, 0, 2);
tft.drawString("ms to draw", xpos, 0, 2);
Serial.println(drawTime);
delay(4000);
// See how long slear screen takes
unsigned long timenow = millis();
tft.fillScreen(ILI9341_BLACK);
timenow = millis()-timenow;
Serial.println(timenow);
// Draw bmp image top left corner at x,y = 40,0 which centres the 240 pixel wide bitmap
// Image must fit (one day I will add clipping... but it will slow things down)
drawBMP("240Moon.bmp", 40, 0, BU_BMP);
xpos = 0;
// Now draw the raw image for speed comparison
// Draw image top left corner at x,y = 40,0 which centres the 240 pixel wide bitmap
drawRAW("240Moon.raw", 40, 0, 240, 240);
xpos = 0;
** Function name: drawBMP
** Descriptions: draw a BMP format bitmap to the screen
#define BUFF_SIZE 80
void drawBMP(char *filename, int x, int y, boolean flip) {
if ((x >= tft.width()) || (y >= tft.height())) return;
File bmpFile;
int16_t bmpWidth, bmpHeight; // Image W+H in pixels
//uint8_t bmpDepth; // Bit depth (must be 24) but we dont use this
uint32_t bmpImageoffset; // Start address of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3 * BUFF_SIZE]; // SD read pixel buffer (8 bits each R+G+B per pixel)
uint16_t tftbuffer[BUFF_SIZE]; // TFT pixel out buffer (16-bit per pixel)
uint8_t sd_ptr = sizeof(sdbuffer); // sdbuffer pointer (so BUFF_SIZE must be less than 86)
boolean goodBmp = false; // Flag set to true on valid header parse
int16_t w, h, row, col; // to store width, height, row and column
//uint8_t r, g, b; // brg encoding line concatenated for speed so not used
uint8_t rotation; // to restore rotation
uint8_t tft_ptr = 0; // buffer pointer
// Check file exists and open it
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.println(F("File not found")); // Can comment out if not needed
return;
void drawRAW(char *filename, int16_t x, int16_t y, int16_t rawWidth, int16_t rawHeight) {
File rawFile;
uint8_t sdbuffer[2 * BUFF_SIZE]; // SD read pixel buffer (16 bits per pixel)
if ((rawFile = SD.open(filename)) == NULL) {
return;
rawFile.close();
