Ili9225 indicator making
Hello, I want to measure the temperature value in the form of an indicator on my ili9225 screen. If there is a source, can you send it?
RFE43VW-1YH-DHS-s
in this way or in the form of a similar indicator
datasheet = https://datasheetspdf.com/datasheet/ILI9225.html
It is very unlikely that someone will have the code to do this so you will need to write your own
Can you print to the screen and make the font large ?
Can you write the time to the screen ?
Can you draw part of a circle on the screen ?
Get each of these working with a library of your choice using the library examples as a guide then you can consider combining them into a single display
Let me get to work now, it will be a little difficult :slight_smile:
