ILI9341 and Arduino Uno: the display lights, but does not display anything.
Hello everyone.
I am writing to ask for your information.
I purchased the ILI9341 display for Arduino Uno.
By connecting power to the display with Arduino, the display lights.
I followed all the guides to display text on the display, but I did not succeed.
I want to know how can I view the text on the ILI9341 display with Arduino Uno, therefore, as I have to make the connections and which sketch should I use.
Thank you.
Post a link to the actual display that you have bought.
Then you will get accurate advice.
David.
Problem solved.
Seriously. If you provided the proper information, you would have got your answers last night. Or within an hour or two.
Most importantly, all the other members with the same hardware or similar questions would have benefited from any solutions.
They could still benefit. If you explain what problem(s) you have solved.
This is how Forums work !!!
David.
I found the connections and the sketch for the ILI9341 display and managed to make it work.
I solved the problem.
