ill prefix by saying im using a teensy but want to check with this community on the issue at hand for some guidance.
id like to use 3 encoders and plot there values on a graph. x axis being time and y axis being voltage. i am using KrisKasprzak ILI9341 library to a tft touch display via spi. the display is working and examples work. but i fear my approach in setting up my encoders is wrong.
might be worth mentioning that my over arching goal is once values / line has been plotted on graph you can push encoder button and output the array/ voltage, when triggered to an analog out pin. having the ability to manipulate to loop segments is also of interest.
any guidance would be very much helpful
here is my initial code.
#include <Encoder.h>
#include <ILI9341_t3.h>
#include <ILI9341_t3_Controls.h>
#include <font_Arial.h>
#include <Colors.h>
// Encoder setup
Encoder enc1(2, 3); // Encoder 1 connected to pins 2 and 3
Encoder enc2(4, 5); // Encoder 2 connected to pins 4 and 5
Encoder enc3(6, 7); // Encoder 3 connected to pins 6 and 7
// Display setup
#define FONT_TITLE Arial_16
#define FONT_DATA Arial_10
#define TFT_DC 9
#define TFT_CS 10
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC);
// Graph settings
#define X_ORIGIN 50
#define Y_ORIGIN 200
#define X_WIDE 250
#define Y_HIGH 150
#define X_LOSCALE 0
#define X_HISCALE 1024
#define X_INC 50
#define Y_LOSCALE -1
#define Y_HISCALE 1024
#define Y_INC 100
#define TEXTCOLOR C_WHITE
#define GRIDCOLOR C_GREY
#define AXISCOLOR C_YELLOW
#define BACKCOLOR C_BLACK
#define PLOTCOLOR C_DKGREY
#define VOLTSCOLOR C_RED
#define SINCOLOR C_GREEN
#define COSCOLOR C_BLUE
unsigned long oldTime;
float x;
int Enc1ID, Enc2ID, Enc3ID;
ILI9341_t3 Display(TFT_CS, TFT_DC);
CGraph MyGraph(&Display, X_ORIGIN, Y_ORIGIN, X_WIDE, Y_HIGH, X_LOSCALE, X_HISCALE, X_INC, Y_LOSCALE, Y_HISCALE, Y_INC);
Serial.begin(57600);
Display.begin();
Display.setRotation(1);
Display.fillScreen(C_BLACK);
MyGraph.init("Teensy Graphing", "Sample Number", "Encoder Position", TEXTCOLOR, GRIDCOLOR, AXISCOLOR, BACKCOLOR, PLOTCOLOR, FONT_TITLE, FONT_DATA);
Enc1ID = MyGraph.add("Encoder 1", VOLTSCOLOR);
Enc2ID = MyGraph.add("Encoder 2", SINCOLOR);
Enc3ID = MyGraph.add("Encoder 3", COSCOLOR);
MyGraph.drawGraph();
MyGraph.setMarkerSize(Enc1ID, 0);
MyGraph.setMarkerSize(Enc2ID, 1);
MyGraph.setMarkerSize(Enc3ID, 2);
long enc1Pos = enc1.read();
long enc2Pos = enc2.read();
long enc3Pos = enc3.read();
MyGraph.setX(x);
MyGraph.plot(Enc1ID, enc1Pos);
MyGraph.plot(Enc2ID, enc2Pos);
MyGraph.plot(Enc3ID, enc3Pos);
x += 1;
delay(10);
