!!! Compiling error on the first comment because it's too long !!!
I correctly implemented the blinky exemple on an attiny2313A using Drazzy's work to use the arduino as an ISP to load my code on the attiny2313.
Since there is no bootloader for Attiny2313, I followed this tuto which burn the bootloader after loading the code on the attiny to get the right clock frequency: Program an attiny2313 with an Arduino - Arduino Learning
But when I try to load the screen code to my attiny through my arduino as ISP I get a bunch of errors (I put the errors at the end of the topics because it's a lot).
I am wondering if it's not a library error (like maybe since the library is in the arduino folder, maybe it's not coppied on the attiny or something) because on the second line of error it says "'SPDR' was not declared in this scope".
Also, I know that the attiny2313 doesn't have enough memory to make the ili9341 works, I am just trying out thing until my atmega328 arrives.
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp: In member function 'void Adafruit_SPITFT::writeColor(uint16_t, uint32_t)':
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:30: error: 'SPDR' was not declared in this scope
#define AVR_WRITESPI(x) for (SPDR = (x); (!(SPSR & _BV(SPIF)));)
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:1308:7: note: in expansion of macro 'AVR_WRITESPI'
AVR_WRITESPI(hi);
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:30: note: suggested alternative: 'SPI'
AVR_WRITESPI(hi);
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:45: error: 'SPSR' was not declared in this scope
AVR_WRITESPI(hi);
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:45: note: suggested alternative: 'SPI'
AVR_WRITESPI(hi);
In file included from c:\users\gaeta\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\io.h:99:0,
from c:\users\gaeta\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:90,
from C:\Users\gaeta\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny/Arduino.h:9,
from C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.h:5,
from C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.h:25,
from C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:36:
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:56: error: 'SPIF' was not declared in this scope
!!! There is a lot of other lines that looks just the same, so I will skip to the end where ther might be more usefull stuff. !!!
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:2412:5: note: in expansion of macro 'AVR_WRITESPI'
AVR_WRITESPI(l);
AVR_WRITESPI(l);
AVR_WRITESPI(l);
AVR_WRITESPI(l);
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_SPITFT.cpp:43:56: note: suggested alternative: 'SPI'
AVR_WRITESPI(l);
exit status 1
Erreur de compilation pour la carte ATtiny2313(a)/4313 (No bootloader)
