Hopefully someone here has guidance on what I'm missing.
I purchased a cheap 2.2" TFT screen compatible with the ILI9341 library. Trying to use it with an Adafruit 3V Pro Trinket at the moment. I'm using the Adafruit_ILI9341.h library to run the show.
My reason for wanting to get hardware SPI working is because the draw rate I've got right now is sloooow. The Adafruit GFX fillScreen() method takes almost two and a half seconds to fill my screen in with red. My understanding (and I could be totally wrong) is that I've been using software SPI when I have this thing working, and hardware SPI would be dramatically faster. Unfortunately, I can't seem to get it working.
In terms of wiring, I've got - Pin 9 to the TFT DC; - Pin 10 to the TFT CS; - Pin 11 for TFT_MOSI; - Pin 12 for TFT_MISO; - Pin 8 for TFT_RST; - Pin 13 for TFT_CLK; and - Pin 6 hooked to the TFT LCD Backlight.
This Pinout seems consistent with what is listed on the Trinket Page. I have checked, and double-checked, and triple-checked these connections. I have gone as far as reflowing all of my pins just in case there was something dodgy in the mix, but that didn't seem to resolve anything.
I can get the device working if I use the following constructor:
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_MISO 12
#define TFT_RST 8
#define TFT_CLK 13 //Arduino SCK
#define TFT_LCD 6
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);/code]
My understanding is that this constructor implements the Software SPI? In any event, this works, and I get a screen that performs everything I need it to with the Adafruit_GFX library, but it's slow. Very slow.
There is an alternative constructor that I have tried in lieu of the one above:
[code]
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
This compiles and uploads fine. However, nothing happens on the display if I use this constructor. I get a white screen (presumably because the TFT_LCD backlight is powered) but no other data or displays.
Thinking that maybe it was something wrong with my Pro Trinket, I switched to the exact same setup but used an Uno R3 instead of the Pro Trinket. Same wiring schematic and everything. I figured since the Uno had a serial monitor I might be able to get some better information to debug with. I tried the graphicstest.ino sketch to see if the debugging lines got me anything useful, and...
ILI9341 Test!
Display Power Mode: 0x0
MADCTL Mode: 0x0
Pixel Format: 0x0
Image Format: 0x0
Self Diagnostic: 0x0
Benchmark Time (microseconds)
Screen fill 1448928
Text 144900
... and so on. The 0x0 means the serial communication isn't working here. It's basically the exact same results on the Uno - if I use the long constructor that declares all the pins, screen works fine, but slow. The short one gives me only a white screen, consistent with a lit backlight and nothing else.
My sketch is below. I tried to keep things as simple as possible.
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_MISO 12
#define TFT_RST 8
#define TFT_LCD 6
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
tft.begin();
pinMode(TFT_LCD, OUTPUT);
analogWrite(TFT_LCD,255);
tft.fillScreen(ILI9341_RED);
Anyone able to point me at what I'm missing here? I've tried other libraries (in particular, I liked the Pixel library because it was pretty fast, but it didn't have any built-in font options and I don't have a ton of memory to spare on my project for font data).
