I am creating a flow meter with arduino mega and ILI9341 as the display. But, I have a trouble because the display can't show the strings. I already test the component with an example code and it was fine. can you help me to find where's the problem in my code?
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include "SPI.h"
const int pinMerah[] = {22, 24, 26, 28};
const int pinHijau[] = {30, 32};
const int pinTombol = 5;
const int pinFlowMeter = 2;
const int pinBuzzer = 4;
#define TFT_CLK 13
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 8
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
bool statusTombol = false;
bool statusTombolSebelumnya = false;
int pengambilanDataKe = 0;
bool sistemSiap = false;
volatile int hitungPulsaFlow = 0;
float lajuAliran = 0.0;
float totalLajuAliran = 0.0;
float rataRataAliran = 0.0;
float volume = 0.0;
int hitunganSampel = 0;
unsigned long waktuLama = 0;
int ledAktif = 0;
unsigned long waktuLED = 0;
unsigned long waktuTombolTekan = 0;
unsigned long startTime = 0;
unsigned long endTime = 0;
unsigned long duration = 0;
void flowISR() {
hitungPulsaFlow++;
for (int i = 0; i < 4; i++) {
pinMode(pinHijau[i], OUTPUT);
pinMode(pinMerah[i], OUTPUT);
digitalWrite(pinHijau[i], LOW);
digitalWrite(pinMerah[i], LOW);
pinMode(pinTombol, INPUT_PULLUP);
pinMode(pinBuzzer, OUTPUT);
pinMode(pinFlowMeter, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(pinFlowMeter), flowISR, RISING);
tft.begin();
tft.setRotation(3);
tft.fillScreen(ILI9341_BLACK);
void persiapanAwal() {
tft.setTextColor(ILI9341_WHITE);
tft.setTextSize(2);
tft.setCursor(50, 50);
tft.print("Sistem Siap");
Serial.println("Sistem siap menerima aliran.");
void tampilkanHasil() {
tft.setTextSize(2);
tft.setCursor(20, 50);
tft.print("Vol: ");
tft.print(volume * 1000);
tft.print(" mL");
tft.setCursor(20, 100);
tft.print("Time: ");
tft.print(duration);
tft.print(" s");
Serial.print("Hasil Ke-");
Serial.print(pengambilanDataKe);
Serial.print(" Volume: ");
Serial.print(volume * 1000);
Serial.println(" mL");
Serial.print("Durasi: ");
Serial.print(duration);
Serial.println(" detik");
void abaAba() {
tft.setTextSize(2);
tft.setCursor(30, 50);
tft.print("Siapkan Napas");
for (int i = 0; i < 2; i++) {
digitalWrite(pinHijau[i], HIGH);
ledAktif = 0;
tft.setCursor(30, 100);
tft.print("Ke-");
tft.print(pengambilanDataKe);
Serial.print("Siapkan Napas untuk Pengukuran Ke-");
Serial.println(pengambilanDataKe);
delay(3000);
tft.print("Mulai Meniup");
Serial.println("Mulai Meniup...");
void resetSystem() {
sistemSiap = false;
volume = 0.0;
hitunganSampel = 0;
startTime = 0;
endTime = 0;
duration = 0;
Serial.println("Sistem di-reset.");
statusTombol = digitalRead(pinTombol) == LOW;
if (statusTombol && !statusTombolSebelumnya) {
if (!sistemSiap && pengambilanDataKe < 20) {
pengambilanDataKe++;
Serial.print("Pengambilan Data Ke-");
if (pengambilanDataKe == 11) {
tft.setTextSize(2);
tft.print("Hebat!");
tft.setCursor(50, 100);
tft.print("10 Data Lagi!");
delay(3000);
persiapanAwal();
abaAba();
sistemSiap = true;
volume = 0.0;
} else if (pengambilanDataKe == 20) {
Serial.println("Pengambilan data selesai.");
tft.setTextSize(2);
tft.print("Selamat!");
tft.print("Semua Selesai!");
delay(5000);
sistemSiap = false;
statusTombolSebelumnya = statusTombol;
if (sistemSiap) {
if ((millis() - waktuLama) > 200) {
if (hitungPulsaFlow > 0 && startTime == 0) {
startTime = millis();
detachInterrupt(digitalPinToInterrupt(pinFlowMeter));
lajuAliran = hitungPulsaFlow / 7.5 * 25;
volume += (lajuAliran / 60.0) * 0.2;
tft.setTextSize(2);
tft.print("Laju: ");
tft.print(lajuAliran, 2);
tft.print(" L/m");
tft.print("Vol: ");
tft.print(" mL");
waktuLama = millis();
if (lajuAliran == 0 && volume > 0) {
endTime = millis();
duration = (endTime - startTime) / 1000;
tampilkanHasil();
sistemSiap = false;
