I'm using a MKR WIFI 1010 and the ENV shield. I try to read the illuminance value amongst others.
The Board is positioned on a shelf in a bathroom. The bathroom has no windows and only a light, which is mostly turned off. The lux value doesn't seem to have any correspondence to the actual lighting situation in the room. I even tried to shine some led light of my mobile phone on the sensor which hadn't any effect at all.
I attached two screenshots of the lux value that I read in my code. The picture with the smaller time span has for sure a light turned on in that room at 7:19. On the larger time scale several people used the bathroom with the light turned on. In the night the room is dark even with opened door.
Am I doing something wrong here? Do I need to average that value? I would suppose to see a difference between turned on light and the night. Could the sensor be broken? Hope someone can help me out here.
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
#include <Arduino_MKRENV.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS; // the Wifi radio's status
int backoff = 5000;
// Specify IP address or hostname
int humidity, lux, pressure, uva;
float temperature;
unsigned int localPort = 2390; // local port to listen on
unsigned int remotePort = 2392;
unsigned int timelocalPort = 2391; // local port to listen on
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte timepacketBuffer[ NTP_PACKET_SIZE];
WiFiUDP measDataUdp;
WiFiUDP TimeUdp;
// Initialize serial and wait for port to open:
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
Serial.println("Current Firmware:");
Serial.println(fv);
Serial.println("Required Firmware");
Serial.println(WIFI_FIRMWARE_LATEST_VERSION);
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(SECRET_SSID);
// Connect to WPA/WPA2 network:
status = WiFi.begin(SECRET_SSID, SECRET_PASS);
delay(backoff);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
printCurrentNet();
printWiFiData();
//setup sensors
if (!ENV.begin()) {
Serial.println("Failed to initialize MKR ENV shield!");
while(1);
//start udp
Serial.println("Starting connection to data server...");
// if you get a connection, report back via serial:
measDataUdp.begin(localPort);
Serial.println("Starting ntp udp socket...");
TimeUdp.begin(timelocalPort);
String meas_string, time_string, str_seconds = "";
String hours, minutes, seconds = "";
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
unsigned long secsSince1900, lowWord, highWord, epoch;
Serial.println("Retrieving Time");
sendNTPpacket(); // send an NTP packet to a time server
// wait to see if a reply is available
if (TimeUdp.parsePacket()) {
Serial.println("packet received");
// We've received a packet, read the data from it
TimeUdp.read(timepacketBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
highWord = word(timepacketBuffer[40], timepacketBuffer[41]);
lowWord = word(timepacketBuffer[42], timepacketBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = ");
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// subtract seventy years:
epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
hours = String((epoch % 86400L) / 3600 + 2);
minutes = String((epoch % 3600) / 60);
seconds = String(epoch % 60);
time_string = hours + ":" + minutes + ":" + seconds;
Serial.println(time_string);
// wait ten seconds before asking for the time again
delay(10000);
Serial.println("Reading sensors...");
humidity = int(ENV.readHumidity()); //in percent
lux = int(ENV.readIlluminance());
pressure = int(ENV.readPressure()); //in kPa
temperature = ENV.readTemperature();
uva = int(ENV.readUVA());
Serial.print("Humidity relative[%]: ");
Serial.println(humidity);
Serial.print("Lux : ");
Serial.println(lux);
Serial.print("Pressure [kPa]: ");
Serial.println(pressure);
Serial.print("Temperature [C]: ");
Serial.println(temperature);
Serial.print("uva : ");
Serial.println(uva);
Serial.println("--------------");
// send a reply, to the IP address and port that sent us the packet we received
measDataUdp.beginPacket("buechse", remotePort);
meas_string = String(epoch) + ";" + String(humidity) + ";" + String(lux) + ";" + String(pressure) + ";" + String(temperature) + ";" + String(uva) + ";" + 999; //999 is a placeholder for the infrared sensor
measDataUdp.println(meas_string);
measDataUdp.endPacket();
delay(10000);
void printWiFiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP address : ");
Serial.println(ip);
Serial.print("Subnet mask: ");
Serial.println((IPAddress)WiFi.subnetMask());
Serial.print("Gateway IP : ");
Serial.println((IPAddress)WiFi.gatewayIP());
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI): ");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type: ");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
// send an NTP request to the time server at the given address
void sendNTPpacket() {
//Serial.println("1");
// set all bytes in the buffer to 0
memset(timepacketBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
//Serial.println("2");
timepacketBuffer[0] = 0b11100011; // LI, Version, Mode
timepacketBuffer[1] = 0; // Stratum, or type of clock
timepacketBuffer[2] = 6; // Polling Interval
timepacketBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
timepacketBuffer[12] = 49;
timepacketBuffer[13] = 0x4E;
timepacketBuffer[14] = 49;
timepacketBuffer[15] = 52;
//Serial.println("3");
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
TimeUdp.beginPacket("pool.ntp.org", 123); //NTP requests are to port 123
//Serial.println("4");
TimeUdp.write(timepacketBuffer, NTP_PACKET_SIZE);
//Serial.println("5");
TimeUdp.endPacket();
//Serial.println("6");
