I'm a noob and I need help
So, I'm quite new at Arduino coding, just started a few days ago... My friend gave a problem sheet about coding in Arduino IDE, one of the problems is:
"Write a program and upload 2 values to the serial monitor where the greater value is shown 15 times."
I made something that kinda works but I think that there is some better way to do it, if anyone got ideas or is able to do it, please tell me. Thnx
Here is my code
int x;
int y = 15;
bool stopLoop = false;
if(stopLoop == false){
for(int x = 1; x <= y; x++) {
Serial.println(y);
delay(100);
stopLoop = true;
This code only works if x = 1 and y = 15 or if the number's difference is 14, so it that is why I think there probably way better ways to do this.
We don't know whether there is some better way to do it. :astonished:
Tell you what though, read the instructions! :grinning:
:o Oops
Post your code in tags, and we can help you improve it
CalciumMax:
Instructions incomplete... what happens to the lesser value? Displayed once? Never? What?
We cannot read your code :o
Your friend is a teacher who wants you to complete a programming assignment ?
Oh and what should happen if the numbers are equal :wink:
He is indeed a friend with the same age, but he is an Arduino genius and he wants me to practice, he allows me to find help tho (researching, asking, tutorials, etc.)
Here is my code
int x;
int y = 15;
Serial.println(y);
delay(100);
stopLoop = true;
Only show the greater value, if they are equal then choose one to display.
Surely you need 3 values? The 2 to choose between to display, and 15 for how many times to display?
I did it as below, with the whole thing in setup() so there's no need to force it to stop after once through loop(), although I applaud your use of the flag to do that.
byte a = 12;
byte b = 12;
byte theBiggerNumber;
  Serial.print("The numbers are ");
  Serial.print(a);
  Serial.print(" and ");
  Serial.print(b);
  if (a > b)
    theBiggerNumber = a;
    theBiggerNumber = b; //or equal
  Serial.println(" and here are 15 copies of the bigger (or equal) number:");
  for (byte i = 0; i < 15; i++)
    Serial.print(theBiggerNumber);
    Serial.print(" ");
  Serial.println(" ");
} //setup
} //loop
