So i have a tiny led lamp connected to the port 5 of my NodeMCU. And I activate it with Alexa (alexa updates IFTTT and IFTTT updates Adafruit IO) so everything here works until I arrive at the WHILE in the code.
I have 4 commands
ON (IF)
OFF (IF)
PULSE(IF)
BLINK (WHILE)
In fact, if I try to “BLINK” the light in this condition and I try to exit with an “OFF” command the light is just irresponsive and keeps on blinking.
Checking on my Adafruit dashboard I see the new command (so it updates there). However, it seems like the following code
if (!strcmp((char*) onoff.lastread, "OFF"))
is not able to recognize the new char* and it is stuck at the old one (BLINK).
I apologize for the position of the parenthesis and other things but I am a real noob in this. This is the full main loop.
MQTT_connect();
Adafruit_MQTT_Subscribe * subscription;
while (subscription = mqtt.readSubscription(5000))
if (subscription == &onoff)
if (!strcmp((char*) onoff.lastread, "ON"))
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
while (!strcmp((char*) onoff.lastread, "PULSE"))
float in, out;
for (in = 0; in < 6.283; in = in + 0.001)
out = sin(in) * 127.5 + 127.5;
analogWrite(5,out);
while (!strcmp((char*) onoff.lastread, "BLINK"))
delay(250);
delay(250);
if (!strcmp((char*) onoff.lastread, "OFF")){
if (!mqtt.ping())
mqtt.disconnect();
It would be nice if someone could give me some options (i also tried the DO WHILE loop but no luck)
Thank you very much also if you just visited and read without answering!
Welcome to the forums. Thank you very much for using code tags to post your code, although you should always post your complete sketch. Who knows how you defined your variables, etc. unless we can see them.
As for your code, I think you want to be using if()… else clauses. You simply test for onoff to be “ON” and then turn on an led. Then you test for “OFF”, etc. If it is “ON”, it can’t be “OFF” or “BLINK” or anything else.
I’m not that familiar with MQTT, so you may need to tweak this:
MQTT_connect();
while (subscription = mqtt.readSubscription(5000)) {
if (subscription == &onoff) {
if (!strcmp((char*) onoff.lastread, "ON")) {
else if (!strcmp((char*) onoff.lastread, "OFF")) {
else if (!strcmp((char*) onoff.lastread, "PULSE")) {
float in, out;
for (in = 0; in < 6.283; in = in + 0.001) {
analogWrite(5, out);
else if (!strcmp((char*) onoff.lastread, "BLINK")) {
delay(250);
delay(250);
if (!mqtt.ping()) {
mqtt.disconnect();
Also, it is not a good idea to use a ‘float’ as the index in a for() loop since they are not precise. You also iterate over 6000 times given your current step size. The analogWrite() function takes an value between 0-255 so your loop is constantly being truncated and the same value gets written many times.
As for the parenthesis, etc. Format your code with Ctrl-T in the IDE.
