I'm back ... what IDE should I use ?
After some years off the arduino I'm back and should install the IDE - I installed the version 2.3.2 !
BUT ...
  1. I think it's very slow, and often
  2. a text "Loading ..." is showing up ... I beleave it tries to show some details on the topic near the cursor,
  3. too, I thought "Intillisence" was implementes ... it just shows "Loading ..." forever !
what is wrong ?
As your questions relate to IDE 2.x, I have moved your topic to the dedicated IDE 2.x section of the forum.
I don't have access at this moment to a system with IDE 2.x so can't advise. However, IDE 2.x was quite slow in loading on a 2nd generation I3 with 8 GB memory and non-SSD hard disks.
Should I just stay in version 1.X or go PlatformIO ?
I do not know what wisdom is; a number of the IDE 2.x feature are nice. I'm currently using a 32 bit version of IDE 1.8.19 and I do miss the autocomplete.
Me too ... it's just showing me a text: "Loading ..." and I've never seen it finishing 'loading' ... so Intellisence/autocomplete my BEEP :rage:
I like my 1.8.19 running on RPi Linux better than the 2.whatever I had.
@ksor
When I updated to 2.x.x, the IDE almost became unusable and would never finish updates/downloads/loading of things… i couldn’t even type of letter of code without my computer fan running full speed and cpu overheating… :man_shrugging:t2:
Not sure if this will help you but it helped me tremendously. I limit and only allow the IDE access to half of my cpu cores…
The hints may depend on the compiler back-end, which would vary for different boards. I'm using a vendor variant of arduino-esp32 v2.0.14. Seems like a full successful compile -- aka Verify -- is needed at startup. It kind of keeps up as I edit -- there are brief "Building sketch" messages in the bottom-left corner -- but I'm not surprised when it goes back to being stuck "Loading..."
#kenb4
I think that's a sign to drop version 2 and got for PerformIO - right ?
Is something wrong with IDE 1.8?
V2 is not V1 improved. It's some people's idea of better that's not finished baking yet.
You must use what works for you. Test the options (IDE 2.x, IDE 1.x, PlatformIO, ...) and use what you like best.
IDE 1.8 ... no I don't think something's wrong - I think you're right ... V2 is not finished baking !
When I last worked as a nobbyist with arduino I tried PerformIO and liked it - so I think I'll install that again
EDIT: I just tried to DELETE/RENAME some TABs for making them a library instead:
WHAT ??????
I can't delete a tab !!!
I can't rename a tab !!!
