Hi, before anything please consider that I'm a complete noob. And I have a few doubts and questions that may seem ridiculous to you so please go easy on me
So I'm building an antenna rotator based on SatNOGS v2 which is the one that looks easiest to build for me, they are using an Arduino Pro Mini connected to their own controller board, I intend using stronger steppers controlled with TB6600 controllers, by looking at their code I'm having some questions. First one there's this:
#define DIR_AZ 18 //PIN for Azimuth Direction
but looking at the arduino pro mini pinout I find no pin 18
Then there's this:
#define MS1 9 //PIN for step size
but the stepper controllers (TB6600) don't have a step size connection, it's done using dip switches.
Also another thing I would like to do it control it via WIFI, someone told me that the code could be changed to work directly using an ESP32 or leave the code unchanged and use a separate ESP32 connected to a regular arduino to act as a WIFI to Serial converter, how would I do that and how would I interconnect both boards?
I know these are noob questions but the only experience with arduinos was bulding a 3d printed clock which was basically just write the code to the arduino nano and connecting like the diagram and it just worked, but this is a bit more complex for me.
The only thing different in terms of hardware is I'm using 50:1 gear ratio instead of 60:1 and I'm using larger steppers with different controllers, I'll be also using to optical homing sensors.
I can't upload files because I'm new so I hope I don't break any rules by pasting it here:
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include <AccelStepper.h>
#define STEP_AZ 10 //PIN for Azimuth Steps
#define DIR_EL 6 //PIN for Elevation Direction
#define STEP_EL 7 //PIN for Elevation Steps
#define EN 8 //PIN for Enable or Disable Stepper Motors
#define SPR 200 //Step Per Revolution
#define RATIO 60 //Gear ratio
#define T_DELAY 60000 //Time to disable the motors in millisecond
#define HOME_AZ 4 //Homing switch for Azimuth
#define HOME_EL 5 //Homing switch for Elevation
/*The MAX_ANGLE depends of ANGLE_SCANNING_MULT and maybe misbehave for large values*/
#define ANGLE_SCANNING_MULT 180 //Angle scanning multiplier
#define MAX_AZ_ANGLE 360 //Maximum Angle of Azimuth for homing scanning
#define MAX_EL_ANGLE 360 //Maximum Angle of Elevation for homing scanning
#define HOME_DELAY 6000 //Time for homing Decceleration in millisecond
/*Global Variables*/
unsigned long t_DIS = 0; //time to disable the Motors
/*Define a stepper and the pins it will use*/
AccelStepper AZstepper(1, STEP_AZ, DIR_AZ);
AccelStepper ELstepper(1, STEP_EL, DIR_EL);
/*Change these to suit your stepper if you want*/
AZstepper.setMaxSpeed(150);
AZstepper.setAcceleration(50);
ELstepper.setMaxSpeed(150);
ELstepper.setAcceleration(50);
/*Enable Motors*/
pinMode(EN, OUTPUT);
digitalWrite(EN, LOW);
/*Step size*/
pinMode(MS1, OUTPUT);
digitalWrite(MS1, LOW); //Full step
/*Homing switch*/
pinMode(HOME_AZ, INPUT);
pinMode(HOME_EL, INPUT);
/*Serial Communication*/
Serial.begin(19200);
/*Initial Homing*/
Homing(deg2step(-ANGLE_SCANNING_MULT), deg2step(-ANGLE_SCANNING_MULT));
/*Define the steps*/
static int AZstep = 0;
static int ELstep = 0;
/*Time Check*/
if (t_DIS == 0)
t_DIS = millis();
/*Disable Motors*/
if (AZstep == AZstepper.currentPosition() && ELstep == ELstepper.currentPosition() && millis()-t_DIS > T_DELAY)
digitalWrite(EN, HIGH);
/*Enable Motors*/
/*Read the steps from serial*/
cmd_proc(AZstep, ELstep);
/*Move the Azimuth & Elevation Motor*/
stepper_move(AZstep, ELstep);
/*Homing Function*/
void Homing(int AZsteps, int ELsteps)
int value_Home_AZ = HIGH;
int value_Home_EL = HIGH;
int n_AZ = 1; //Times that AZ angle has changed
int n_EL = 1; //Times that EL angle has changed
boolean isHome_AZ = false;
boolean isHome_EL = false;
AZstepper.moveTo(AZsteps);
ELstepper.moveTo(ELsteps);
while(isHome_AZ == false || isHome_EL == false)
value_Home_AZ = digitalRead(HOME_AZ);
value_Home_EL = digitalRead(HOME_EL);
/* Change to LOW according to Home sensor */
if (value_Home_AZ == HIGH)
AZstepper.moveTo(AZstepper.currentPosition());
isHome_AZ = true;
if (value_Home_EL == HIGH)
ELstepper.moveTo(ELstepper.currentPosition());
isHome_EL = true;
if (AZstepper.distanceToGo() == 0 && !isHome_AZ)
n_AZ++;
AZsteps = deg2step(pow(-1,n_AZ)*n_AZ*ANGLE_SCANNING_MULT);
if (abs(n_AZ*ANGLE_SCANNING_MULT) > MAX_AZ_ANGLE)
error(0);
if (ELstepper.distanceToGo() == 0 && !isHome_EL)
n_EL++;
ELsteps = deg2step(pow(-1,n_EL)*n_EL*ANGLE_SCANNING_MULT);
if (abs(n_EL*ANGLE_SCANNING_MULT) > MAX_EL_ANGLE)
error(1);
AZstepper.run();
ELstepper.run();
/*Delay to Deccelerate*/
long time = millis();
while(millis() - time < HOME_DELAY)
AZstepper.run();
ELstepper.run();
/*Reset the steps*/
AZstepper.setCurrentPosition(0);
ELstepper.setCurrentPosition(0);
/*EasyComm 2 Protocol & Calculate the steps*/
void cmd_proc(int &stepAz, int &stepEl)
/*Serial*/
char buffer[256];
char incomingByte;
char *p=buffer;
char *str;
static int counter=0;
char data[100];
double angleAz,angleEl;
/*Read from serial*/
while (Serial.available() > 0)
incomingByte = Serial.read();
/* XXX: Get position using custom and test code */
if (incomingByte == '!')
/* Get position */
Serial.print("TM");
Serial.print(1);
Serial.print(" ");
Serial.print("AZ");
Serial.print(10*step2deg(AZstepper.currentPosition()), 1);
Serial.print(" ");
Serial.print("EL");
Serial.println(10*step2deg(ELstepper.currentPosition()), 1);
/*new data*/
else if (incomingByte == '\n')
p = buffer;
buffer[counter] = 0;
if (buffer[0] == 'A' && buffer[1] == 'Z')
if (buffer[2] == ' ' && buffer[3] == 'E' && buffer[4] == 'L')
/* Get position */
Serial.print("AZ");
Serial.print(step2deg(AZstepper.currentPosition()), 1);
Serial.print(" ");
Serial.print("EL");
Serial.print(step2deg(ELstepper.currentPosition()), 1);
Serial.println(" ");
/*Get the absolute value of angle*/
str = strtok_r(p, " " , &p);
strncpy(data, str+2, 10);
angleAz = atof(data);
/*Calculate the steps*/
stepAz = deg2step(angleAz);
if (str[0] == 'E' && str[1] == 'L')
angleEl = atof(data);
stepEl = deg2step(angleEl);
/* Stop Moving */
else if (buffer[0] == 'S' && buffer[1] == 'A' && buffer[2] == ' ' && buffer[3] == 'S' && buffer[4] == 'E')
/* Get position */
Serial.print("AZ");
Serial.print(" ");
Serial.print("EL");
Serial.println(step2deg(ELstepper.currentPosition()), 1);
stepAz = AZstepper.currentPosition();
stepEl = ELstepper.currentPosition();
/* Reset the rotator */
else if (buffer[0] == 'R' && buffer[1] == 'E' && buffer[2] == 'S' && buffer[3] == 'E' && buffer[4] == 'T')
/* Get position */
Serial.print("AZ");
Serial.print(" ");
Serial.print("EL");
/*Move the steppers to initial position*/
Homing(0,0);
/*Zero the steps*/
stepAz = 0;
stepEl = 0;
counter = 0;
/*Reset the disable motor time*/
t_DIS = 0;
/*Fill the buffer with incoming data*/
else {
buffer[counter] = incomingByte;
counter++;
/*Error Handling*/
void error(int num_error)
switch (num_error)
/*Azimuth error*/
case (0):
while(1)
Serial.println("AL001");
delay(100);
/*Elevation error*/
case (1):
while(1)
Serial.println("AL002");
delay(100);
default:
while(1)
Serial.println("AL000");
delay(100);
/*Send pulses to stepper motor drivers*/
void stepper_move(int stepAz, int stepEl)
AZstepper.moveTo(stepAz);
ELstepper.moveTo(stepEl);
AZstepper.run();
ELstepper.run();
/*Convert degrees to steps*/
int deg2step(double deg)
return(RATIO*SPR*deg/360);
/*Convert steps to degrees*/
double step2deg(int Step)
return(360.00*Step/(SPR*RATIO));
