I’m on project to operate the barcode scanner.
my problem might be simple or super hard.
I don’t know why this error comment appear.
this comment says that the problme is in the library in my PS3BT.cpp but it is possible that i open that cpp file, modify the wrong point and save? I’m not sure the meaning of the comment.
looking for someone to help me.
C:\Program Files (x86)\Arduino\libraries\USB_Host_Shield_2.0-master\PS3BT.cpp: In member function ‘float PS3BT::getAngle(AngleEnum)’:
C:\Program Files (x86)\Arduino\libraries\USB_Host_Shield_2.0-master\PS3BT.cpp:107: error: ‘atan2f’ was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\USB_Host_Shield_2.0-master\PS3BT.cpp:109: error: ‘atan2f’ was not declared in this scope
My current code is:
Portable barcode scanner. Uses USB HID barcode scanner, Arduino Board, USB Host Shield and HD44780-compatible LCD display
The circuit:
- LCD RS pin to digital pin 7
- LCD Enable pin to digital pin 6
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
- LCD R/W pin to ground
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
#include <hid.h>
#include <hiduniversal.h>
#include <LiquidCrystal.h>
#include <avr/pgmspace.h>
//#include <avrpins.h>
//#include <max3421e.h>
//#include <usbhost.h>
//#include <usb_ch9.h>
#include <Usb.h>
#include <usbhub.h>
//#include <address.h>
#include <hidboot.h>
#include <SPI.h>
//#include <printhex.h>
//#include <message.h>
//#include <hexdump.h>
//#include <parsetools.h>
#define DISPLAY_WIDTH 16
// initialize the LCD library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard(&Usb);
class KbdRptParser : public KeyboardReportParser
void PrintKey(uint8_t mod, uint8_t key);
protected:
virtual void OnKeyDown (uint8_t mod, uint8_t key);
virtual void OnKeyPressed(uint8_t key);
void KbdRptParser::OnKeyDown(uint8_t mod, uint8_t key)
uint8_t c = OemToAscii(mod, key);
if (c)
OnKeyPressed(c);
/* what to do when symbol arrives */
void KbdRptParser::OnKeyPressed(uint8_t key)
static uint32_t next_time = 0; //watchdog
static uint8_t current_cursor = 0; //tracks current cursor position
if( millis() > next_time ) {
lcd.clear();
current_cursor = 0;
delay( 5 ); //LCD-specific
lcd.setCursor( 0,0 );
}//if( millis() > next_time …
next_time = millis() + 200; //reset watchdog
if( current_cursor++ == ( DISPLAY_WIDTH + 1 )) { //switch to second line if cursor outside the screen
lcd.setCursor( 0,1 );
Serial.println( (char)key );
lcd.print( (char)key );
KbdRptParser Prs;
Serial.begin( 115200 );
Serial.println(“Start”);
if (Usb.Init() == -1) {
Serial.println(“OSC did not start.”);
delay( 200 );
Hid.SetReportParser(0, (HIDReportParser*)&Prs);
// set up the LCD’s number of columns and rows:
lcd.begin(DISPLAY_WIDTH, 2);
lcd.clear();
lcd.noAutoscroll();
lcd.print(“Ready”);
delay( 200 );
Usb.Task();
