So, in my code, im making a little game about reaction timing, and I have an error about a non declared variable on the fourth if statement, but on the three previous if statements it compiled fine, I will put the loop and the function with the error
void flashLight() {
//4 if statements running at same time to check what number the random produced
if (randomLight == 1) {
digitalWrite(light1, HIGH);
bu1 = 1;
if (randomLight == 2) {
digitalWrite(light2, HIGH);
bu2 = 1;
if (randomLight == 3) {
digitalWrite(light3, HIGH);
bu3 = 1;
if (randomLight == 4) {
digitalWrite(light4, HIGH);
bu4 = 1;
Function ^^^
Loop ///
int randomLight = random(1, 4);
flashLight();
beginCountdown();
Error /
exit status 1
'randomLight' was not declared in this scope
You declared a local variable named 'randomLight' in loop().
The variable named 'randomLight' in flashLight() is not declared.
Sounds like you want to declare 'randomLight' as a GLOBAL varible, outside any function, so it can be used to communicate between the two functions that use it.
You should read the documentation on the random() function. random(1,4) will sort-of-randomly return 1, 2, or 3. There is no sense in testing that the value is 4.
PaulS:
Thanks, I never quite read it to the fullest
SkyCrafter:
I was also told that you only put the variable ontop of the if statement when you are using
Could you repeat that in English?
Steve
ENGLISH: I was also told that you only put the variable ontop of the if statement when you are using
SkyCrafter:
Steve
Thanks, that clears it up nicely apart from just a couple of little things...what does "ontop of the if statement" mean? Oh and "when you are using" what? Heroin? A big hammer? Something else?
The individual words are mainly English, but the sentence is meaningless.
