I'm getting a " sim808 init error"
I recently bought a Sim808 GSM/GPRS/GPS module and Arduino mega2560, I wanted to do a basic test but when i run my program I'm getting a " sim808 init error". I'm using a code i found in github, From the following code I want to recieve a sms from the sim 808 module.
//Specify the sim number in the GSM part given at the bottom
#include <SoftwareSerial.h>
SoftwareSerial mySerial(11,10); // RX, TX
char strn[100],coord[50],lati_arr_1[25],lati_arr_2[25],long_arr_1[25],long_arr_2[25];
int c=0,i=0;
double Db_lati_1,Db_lati_2,Db_long_1,Db_long_2,Db_lati,Db_long;
String str_lati,str_long;
  mySerial.begin(9600);
  while(!Serial) {
  for(i = 0; i < 26; i++) {
    lati_arr_1[i] = 0;
    lati_arr_2[i] = 0;
    long_arr_1[i] = 0;
    long_arr_2[i] = 0;
  Serial.println("Starting the GSM and GPS communication");
  // GPS PART
  strn[9] = '\0';
  mySerial.println("AT");    // To check the correct interfacing with sim808(gsm module)
  delay(200);
  for(i = 0; i < 99; i++) {
    strn[i] = 0; // initialising the array to avoid any garbage values
  c = 0;
  while(!mySerial.available());  // if nothing is available to read on the serial pins then this empty loop will be continuosly executed.
  while(mySerial.available()) {
    strn[c] = (mySerial.read());
    if(c < 9) {
      c++;
  } // if there is something available to read in the buffer then response will be stored in strn.
  for (i = 0; i < 20; i++) {
    Serial.print(strn[i]);
  } // strn will be printed on serial monitor.
  Serial.println("");
  c = 0;
  delay(2000);
  mySerial.println("AT+CGPSPWR=1");  // AT command for powering on gps
  delay(200);
    strn[i] = 0;
  c = 0;
    c++;
  for (i = 0; i < c; i++) {
  mySerial.println("AT+CGPSRST=1"); // AT command for resetting GPS
  delay(200);
  delay(200);
    strn[i] = 0;
  c = 0;
    c++;
  mySerial.println("AT+CGPSINF=0"); // AT command for getting the current location
  delay(200);
    strn[i] = 0;
  c = 0;
    Serial.print(strn[c]);
    c++;
  Serial.print("\n ");
  for (i = 27; i < 50; i++) {
    coord[i - 27] = strn[i];      // Here a character array named coord containing the coordinates (latitude,longitude) in degree and minutes format is formed.
  for(i = 0; i < 23; i++) {
    if(i < 2) {
      lati_arr_1[i] = coord[i];
    } else if (i >= 2 && i <= 10) {
      lati_arr_2[i - 2] = coord[i];
    } else if (i >= 12 && i <= 13) {
      long_arr_1[i - 12] = coord[i];
    } else if (i >= 14 && i <= 22) {
      long_arr_2[i - 14] = coord[i];
  // In the above for loop we separated out degree and minute part of latitude and longitude from the
  //coordinates character array 'coord' in 4 different character arrays respectively.
  String lati_1(lati_arr_1);
  String lati_2(lati_arr_2);
  String long_1(long_arr_1);
  String long_2(long_arr_2);  // Here we have converted above 4 character arrays into 4 strings , So that we can directly use
  // function to convert these strings into Doubles.
  //********* String to Double conversion is required,So that we can perform mathematical operation to convert the format of coordinates
  Db_lati_1=lati_1.toDouble();       // here we converted the string lati_1 to double
  Db_lati_2=((lati_2.toDouble())/60);
  Db_lati=Db_lati_1 + Db_lati_2;   // here we have obtained the latitude in the decimal format with double as it's data type.
str_lati=String(Db_lati,6); // Here we have converted the decimal latitude in string('str_lati') , So that we can include it in our 'text' message.
  Db_long_1=long_1.toDouble();
  Db_long_2=((long_2.toDouble())/60);
  Db_long=Db_long_1 + Db_long_2; // here we have obtained the longitude in the decimal format with double as it's data type.
 str_long=String(Db_long,6); // converted it in a string named 'str_long'.
String coord_string = str_lati + ',' + str_long ;    // making a string named as 'coord_string' by concatenating latitude and longitide strings in decimal format with
// a comma in between
String c = "https://www.google.com/maps/place/";
String map_link = c + coord_string ;  // Here we have made a link to access the location on google map.
 // GSM PART
  delay(1500);
  delay(1500);
  mySerial.println("AT+CSCS=\"GSM\"");  // setting for english only message
  delay(1500);
  mySerial.println("AT+CMGF=1");     // set the module in text message mode
  delay(1500);
  mySerial.println("AT+CMGS=\"sim_number\"");  // to send message at a particular number
  delay(1500);
  mySerial.println("\n LOCATION IS " + coord_string+ "\n" + map_link);  // appending the text message with location
  delay(2000);
  if (mySerial.available()) { //if there is some data available on pin 7 or 8 then it'll show on serial monitor.
    Serial.write(mySerial.read());
    if (Serial.available()) { // allows to write AT commands during execution of programme or in case of any error.
    mySerial.write(Serial.read());
Are your SoftwareSerial RX and TX in the correct order?
i checked it ,yes the RX and TX are in correct order
the Mega has four hardware serial ports why are you using SoftwareSerial?
give a link to to SIM808 module?
in particular check the SIM808 IO voltage - the mega uses 5V logic - if the SIM808 uses 3.3V logic you could damage it
