I'm got Stucked with this error PlZZZ Help
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, RainMaker, 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None"
Sketch uses 1782925 bytes (56%) of program storage space. Maximum is 3145728 bytes.
Global variables use 53012 bytes (16%) of dynamic memory, leaving 274668 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.3
Serial port COM5
Connecting....
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 7c:9e:bd:49:2f:d4
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x001c4fff...
Flash params set to 0x022f
Compressed 18880 bytes to 12992...
Writing at 0x00001000... (100 %)
Wrote 18880 bytes (12992 compressed) at 0x00001000 in 0.2 seconds (effective 644.4 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 524.3 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 2095.9 kbit/s)...
Compressed 1788704 bytes to 1174691...
Writing at 0x00010000... (1 %)
Writing at 0x0001b791... (2 %)
Writing at 0x00027619... (4 %)
Writing at 0x0003230c... (5 %)
Writing at 0x0003ad70... (6 %)
Writing at 0x0003fa13... (8 %)
Writing at 0x00044e6e... (9 %)
Writing at 0x0004be08... (11 %)
Writing at 0x00055e54... (12 %)
Writing at 0x00062da5... (13 %)
Writing at 0x000683a1... (15 %)
Writing at 0x0006d7c4... (16 %)
Writing at 0x00072fc2... (18 %)
Writing at 0x000781a0... (19 %)
Writing at 0x0007d2e0... (20 %)
Writing at 0x000825e4... (22 %)
Writing at 0x00087984... (23 %)
Writing at 0x0008cbde... (25 %)
Writing at 0x00092587... (26 %)
Writing at 0x00097c66... (27 %)
Writing at 0x0009d117... (29 %)
Writing at 0x000a2857... (30 %)
Writing at 0x000a7ae4... (31 %)
Writing at 0x000adeb8... (33 %)
Writing at 0x000b37c6... (34 %)
Writing at 0x000b9460... (36 %)
Writing at 0x000bec14... (37 %)
Writing at 0x000c4551... (38 %)
Writing at 0x000ca212... (40 %)
Writing at 0x000cfa42... (41 %)
Writing at 0x000d5214... (43 %)
Writing at 0x000db187... (44 %)
Writing at 0x000e1268... (45 %)
Writing at 0x000e7c1c... (47 %)
Writing at 0x000ee391... (48 %)
Writing at 0x000f3bb4... (50 %)
Writing at 0x000f99ed... (51 %)
Writing at 0x000fef43... (52 %)
Writing at 0x0010469a... (54 %)
Writing at 0x0010a264... (55 %)
Writing at 0x0010fa0d... (56 %)
Writing at 0x001157a3... (58 %)
Writing at 0x0011b625... (59 %)
Writing at 0x00121a1e... (61 %)
Writing at 0x001276a3... (62 %)
Writing at 0x0012cd28... (63 %)
Writing at 0x00132144... (65 %)
Writing at 0x001377d3... (66 %)
Writing at 0x0013cbb7... (68 %)
Writing at 0x00141c35... (69 %)
Writing at 0x001470db... (70 %)
Writing at 0x0014cde5... (72 %)
Writing at 0x00152310... (73 %)
Writing at 0x001575d4... (75 %)
Writing at 0x0015cb8a... (76 %)
Writing at 0x00161df3... (77 %)
Writing at 0x0016721d... (79 %)
Writing at 0x0016c70d... (80 %)
Writing at 0x00171d49... (81 %)
Writing at 0x001774b0... (83 %)
Writing at 0x0017d08c... (84 %)
Writing at 0x00182ac0... (86 %)
Writing at 0x00188232... (87 %)
Writing at 0x00190f9f... (88 %)
Writing at 0x00199589... (90 %)
Writing at 0x0019f820... (91 %)
Writing at 0x001a4822... (93 %)
Writing at 0x001aada2... (94 %)
Writing at 0x001b0441... (95 %)
Writing at 0x001b6243... (97 %)
Writing at 0x001bb59a... (98 %)
Writing at 0x001c0af1... (100 %)
Wrote 1788704 bytes (1174691 compressed) at 0x00010000 in 15.2 seconds (effective 944.1 kbit/s)...
File md5: ed2e5e06ccaa8337c27ccabf1afcd885
Flash md5: 683dc56144447d356661064467224e49
MD5 of 0xFF is 747921e85a0b82a274a9366deb854709
A fatal error occurred: MD5 of file does not match data in flash!
option enabled in File -> Preferences.
Welcome to the forum
How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
Looks like somewhere between the compression, transmission, expansion, and storage of the program, something went wrong and it didn't verify. Do you always get the same two MD5 hashes when you try? If the hashes stay the same it might be a software error. If one or both of the hashes change each time, it's more likely a hardware problem.
Go on then, do what you told and report back
File md5: 6e17ba0aba7160c9d8d01ee6c7b5c610
Flash md5: ca68b38f7233bd47b0d2c2b01a9ec44d
MD5 of 0xFF is 33ac56c262276de443d5a37059c743df
Hashes are Changing Every Time i Upload
is There Anyway to Recover
I don't know. Your sketch is fairly large at 1.8 Mb. Can you successfully upload a smaller sketch?
I Had Already Uploaded the Code in the Esp32 DevkitV1 Board. But Again a small edit in the code i have only changed the variables GPIO PINS And I tried Blank Codes, Example Codes Same Error Appears
