Dear sir,
please help us
Through Arduino Uno + Ethernet-shield i am getting problems. i am writing two Arduino code 1 st one is running, send data to serial monitor & Mysql data base But my second Arduino Code running , send data to serial monitor but & data does not received in Mysql data base.
First Code
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Setting MAC Address
int ledPin=7;
int inPin=7;
int rpm;
char X;
int Time;
int val = 0;
int sensorPin = A0;
int sensorValue = 0;
char server[] = "192.168.137.1";
IPAddress ip(192,168,137,40);
EthernetClient client;
/* Setup for Ethernet and RFID */
pinMode(ledPin,OUTPUT);
pinMode(inPin, INPUT);
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
/* Infinite Loop */
void loop(){
long duration;
val = digitalRead(inPin);
digitalWrite(ledPin, val);
duration = pulseIn(inPin, LOW);
Time = duration/60;
rpm= 600000/Time;
Sending_To_phpmyadmindatabase();
delay(10000); // interval
void Sending_To_phpmyadmindatabase() //CONNECTING WITH MYSQL
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
Serial.print("GET /testcode/dht.php?humidity=");
client.print("GET /testcode/dht.php?humidity="); //YOUR URL
Serial.println(rpm);
client.print(rpm);
client.print("&temperature=");
Serial.println("&temperature=");
client.print(Time);
Serial.println(Time);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.println();
client.println("Host: 192.168.137.1");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
Second Code
#include <SPI.h>
int ledPin=7;
int inPin=7;
int rpm;
char X;
int Time;
int val = 0;
int sensorPin = A0;
/* Infinite Loop */
void loop(){
long duration;
Time = duration/60;
rpm= 600000/Time;
if (rpm==-1){
sensorValue = analogRead(sensorPin);
if (sensorValue<20){
char X[]="Weft St";}
if (sensorValue >50 && sensorValue<350){
char X[]="Warp St";}
if (sensorValue > 800){
char X[]="Weft Jam";}
else {
char X[]=" ";
client.print(rpm);
client.print(X);
Serial.println(X);
client.println();
client.println();
Thanks & best Regards
Pramod Goswami
Whats app No.:- +918058718545
