prizm.setmotorSpeeds(5,5);
what is wrong here?
what is wrong here?
What is wrong is that you did not post your whole sketch or the error message
#include <PRIZM.h>
PRIZM prizm;
int wheelDiam = 4;
float wheelCirc = wheelDiam*M_PI;
long totalTime = 3;
int totalDist = 0;
prizm.PrizmBegin () ;
for (int x = 0; x<=720; x=x+5) {
prizm.setGreenLED(HIGH);
prizm.resetEncoders();
long startTime = millis();
while(prizm.readLineSensor)(3) == 0) { }
totalTime = round ((millis() - start Time)/1000);
totalDist = round(prizm.readEncoderDegrees (1) * wheelCirc / 360);
prizm.setMotorPowers(5,5);
displayVelocity();
prizm.PrizmEnd();
void displayVelocity(){
prizm.setGreenLED(LOW);
delay(2000)
int velocity = round(totalDist / totalTime);
for (int i = 0; i<=velocity; i++) {
prizm.setRedLED(HIGH);
prizm.setRedLED(LOW)
delay (500)
So i have errors on the following lines:
delay (500)
Try this:
#include <PRIZM.h>
PRIZM prizm;
int wheelDiam = 4;
float wheelCirc = wheelDiam * M_PI;
long totalTime = 3;
int totalDist = 0;
for (int x = 0; x <= 720; x = x + 5) {
prizm.setmotorSpeeds(5, 5);
while (prizm.readLineSensor)[3] == 0) { }
totalTime = round ((millis() - start Time) / 1000);
totalDist = round(prizm.readEncoderDegrees[1] * wheelCirc / 360);
prizm.setMotorPowers(5, 5);
displayVelocity();
prizm.PrizmEnd();
void displayVelocity() {
delay(2000);
for (int i = 0; i <= velocity; i++) {
prizm.setRedLED(LOW);
delay (500);
No idea if it will work.
Where did the code come from?
i found it on google from a pdf that tetrix prime made
https://asset.pitsco.com/sharedimages/resources/tetrixprizm-arduinoide-referenceguide.pdf
now i have less error at least
these are the lines that are with an error
If this is suppose to be the sketch on page 16, it's not. You changed some parameters.
is most likely it's too small a value to get the motors turning.
You require a finish line of some sort to stop this thing.
What error message are you getting?
while (prizm.readLineSensor[3] == 0) { }
Please specify the error message!
@3lj0shuax - You copied a LOT of typographical errors from the PDF. Missing braces... translating parenthesis as brackets....
Why not use their example code from their library?
Library (zip)
https://www.pitsco.com/sharedimages/resources/TETRIX_PRIZM_080219.zip
A 168 page reference guide... library found
https://asset.pitsco.com/sharedimages/resources/tetrix-prizm-programming-guide.pdf
Here is the code from Post #6 as it should appear... (it compiles using the library zip above)
#include "PRIZM.h"
PRIZM prizm;
int wheelDiam = 4;
long totalTime = 3;
int totalDist = 0;
prizm.setMotorSpeeds(5, 5);
while (prizm.readLineSensor(3) == 0) {
totalTime = round ((millis() - startTime) / 1000);
totalDist = round(prizm.readEncoderDegrees(1) * wheelCirc / 360);
displayVelocity();
prizm.PrizmEnd();
delay(2000);
delay (500);
