This examples shows how to make a simple seven keys MIDI keyboard with volume control
Created: 4/10/2015
Author: Arturo Guadalupi a.guadalupi@arduino.cc
http://www.arduino.cc/en/Tutorial/MidiDevice
#include "MIDIUSB.h"
#include "PitchToNote.h"
#define NUM_BUTTONS 12
const uint8_t button1 = 2;
const uint8_t button2 = 3;
const uint8_t button3 = 4;
const uint8_t button4 = 5;
const uint8_t button5 = 6;
const uint8_t button6 = 7;
const uint8_t button7 = 8;
const uint8_t button8 = 9;
const uint8_t button9 = 130;
const uint8_t button10 = 11; //(0xb) input
const uint8_t button11 = 12; //(0xc) input
const uint8_t button12 = 13; //(0xd) input
const int intensityPot = 0; //A0 input
const uint8_t buttons[NUM_BUTTONS] = {button1, button2, button3, button4, button5, button6, button7, button8, button9, button10, button11, button12};
const byte notePitches[NUM_BUTTONS] = {60, 61, 62 ,63 ,64 ,65 ,66 ,67 ,68 ,69 ,70 ,71};
uint8_t notesTime[NUM_BUTTONS];
uint8_t pressedButtons = 0x00;
uint8_t previousButtons = 0x00;
uint8_t intensity;
for (int i = 0; i < NUM_BUTTONS; i++)
pinMode(buttons[i], INPUT_PULLUP);
readButtons();
readIntensity();
playNotes();
// First parameter is the event type (0x0B = control change).
// Second parameter is the event type, combined with the channel.
// Third parameter is the control number number (0-119).
// Fourth parameter is the control value (0-127).
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
void readButtons()
if (digitalRead(buttons[i]) == LOW)
bitWrite(pressedButtons, i, 1);
delay(50);
bitWrite(pressedButtons, i, 0);
void readIntensity()
int val = analogRead(intensityPot);
intensity = (uint8_t) (map(val, 0, 1023, 0, 127));
void playNotes()
if (bitRead(pressedButtons, i) != bitRead(previousButtons, i))
if (bitRead(pressedButtons, i))
bitWrite(previousButtons, i , 1);
noteOn(0, notePitches[i], intensity);
MidiUSB.flush();
bitWrite(previousButtons, i , 0);
noteOff(0, notePitches[i], 0);
MidiUSB.flush();
// First parameter is the event type (0x09 = note on, 0x08 = note off).
// Second parameter is note-on/note-off, combined with the channel.
// Channel can be anything between 0-15. Typically reported to the user as 1-16.
// Third parameter is the note number (48 = middle C).
// Fourth parameter is the velocity (64 = normal, 127 = fastest).
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
