#include <dht.h>
#define dht_dpin 2 //no ; here. Set equal to channel sensor is on
int relay1 = 12;
dht DHT;
void setup(){
pinMode(relay1, OUTPUT);
delay(300);//Let system settle
Serial.println("Humidity and temperature\n\n");
delay(700);//Wait rest of 1000ms recommended delay before
//accessing sensor
}//end "setup()"
void loop(){
if (DHT.temperature > 25) digitalWrite(relay1, LOW);
if (DHT.temperature < 24) digitalWrite(relay1, HIGH);
//This is the "heart" of the program.
DHT.read11(dht_dpin);
Serial.print("Current humidity = ");
Serial.print(DHT.humidity);
Serial.print("% ");
Serial.print("temperature = ");
Serial.print(DHT.temperature);
Serial.println("C ");
delay(800);//Don't try to access too frequently... in theory
//should be once per two seconds, fastest,
//but seems to work after 0.8 second.
}// end loop()
im just starting out with this but im trying to make a temp and humidity controller and im confused. above i have 2 if value i tried to use else but i was not using it correctly so i tried it that way, the frist if is "if (DHT.temperature > 25) digitalWrite(relay1, LOW);" and to my understanding it should if the temp is greater then 25 it should turn off the relay but its turning it on and the other HIGH is turning it off. and it s actually working the way i need it, the way the code it written.
