I'm making a steering wheel with adruino leonardo. For my throttle and brake I wanted to use these two cheap chinese pedal from Alibaba. These pedal has 3 wires: 5v, negative pole, signal line. If I connect these instead of like how the potentiometer is connected will it work? Or how I can make these work?
Do you have such pedal in hand? - or any documentation for it?
- Using a DMM, confirm if the pedals are simple potentiometers.
The controller is not a power supply. Remove the connection to the 5 volt pin and get a proper 5 volt power supply.
Powering pots is okey but not motors, transmitters, etc.
No but I saw people using it on different project.
like this one : https://www.youtube.com/watch?v=WR_rcnc2bj4
and a post: Hall Sensor Throttle & Brake pedals for RC car - #18 by Railroader
but I don't understand this . I'm completely new on this field.
And what you expecting from the forum? If you don't understand the simplest diagram from Railroader's link - how you hope to fulfil your project that a way more complicated ?
Welcome! This is a very ambisious project even for somebody with some experience. I highly recommend you get the Arduino Cookbook and read it cover to cover before going any further with this project. Also do some tutorials on basic electronics.
Check here for reference posts / tutorials Useful links - check here for reference posts / tutorials
I just wanted to know that will it work if I connect these pedal like picture ? I completed the steering wheel part and it is working. I'm following a video from youtube
but the pedal part will take a lot of time bcoz of it mechanics.
It depends not only on connections, but on your code and your experience.
Is the code compatible with pedals? Why there are a three pots on your diagram, and how you intended replace it with only two pedals?
Someone already did the code and made a software. These 3 pots are for brake, accel and clutch. I'm not gonna use the clutch that's why I'm using just 2 pedals .
This is the video i'm following and he explained it: https://www.youtube.com/watch?v=crdDhvhBG0M
