im new
I onlly havve access to a raspberry pi 4 and im started to get into arduino will this be ok to use to program with as i have no real access to a pc thankyou
I expect so. I've used a Pi V3 to program Arduinos without any problem.
@chrislittler1234, you should always use a Title that summarises what you want advice about. In this case it might be "Can I program an Arduino with a RaspberryPi?" or "Can I run the Arduino IDE on a RaspberryPi?"
That makes it much more likely to get the attention of people who know the answer.
...R
i have no access to a pc only a rasspberry pi 4 due to my budget will this be good enough to use to program arduino
Asked and answered. Since you missed it and ask again, why not try googling
raspberry pi arduino ide
like I just did. You’ll be fine, it seems.
HTH
a7
I've merged your cross-posts @chrislittler1234.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
