Im seeking a bootloader for ATmega8 16 Mhz
Im seeking a bootloader for ATmega8 16 Mhz but i can only find bootloaders who using the internal oscillator. I want to use the external 16 MHz oscillator.
Can you help me?
/ Thanks P
Doesn't this do that?
atmega8.name=Arduino NG or older w/ ATmega8
atmega8.upload.protocol=arduino
atmega8.upload.maximum_size=7168
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf
atmega8.bootloader.high_fuses=0xca
atmega8.bootloader.path=atmega8
atmega8.bootloader.file=ATmegaBOOT-prod-firmware-2009-11-07.hex
atmega8.bootloader.unlock_bits=0x3F
atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=16000000L
atmega8.build.core=arduino
atmega8.build.variant=standard
atmega8.build.f_cpu=16000000L <<< Gotta be external - internal is only 8MHz
CrossRoads:
Thank you!
I haven't notice that Arduino NG did use the ATmega8 withg 16 Mhz :slight_smile:
Yep, NG is the guy. Anyway, good luck with the 10 second wait each startup.
Maybe there's an optiboot for atmega8.
Optiboot also includes support for ATmega8 at 16MHz. The optiboot_atmega8.hex distributed with the Arduino IDE should do it, but you'll have to edit a boards.txt manually. the latest optiboot no longer includes an ATmega8 .hex file, but you can build it yourself.
westfw:
Is my modified boards.txt entry will work on external 16MHz Crystal config. fresh bought blank ATmega8-16PU MCU's?
opti8.name=Arduino w/ Optiboot ATmega8-16PU
opti8.upload.protocol=arduino
opti8.upload.maximum_size=7680
opti8.upload.speed=19200
opti8.bootloader.low_fuses=0xbf
opti8.bootloader.high_fuses=0xcc
opti8.bootloader.path=optiboot
opti8.bootloader.file=optiboot_atmega8.hex
opti8.bootloader.unlock_bits=0x3F
opti8.bootloader.lock_bits=0x0F
opti8.build.mcu=atmega8
opti8.build.f_cpu=16000000L
opti8.build.core=arduino
opti8.build.variant=standard
Thank you!
@beic, please do not cross-post. Please do not hijack.
The answer to your question is here...
http://forum.arduino.cc/index.php?topic=322325.msg2787528#msg2787528
Ohh, yeah, thank you!
