Powered by an Arduino UNO and Arduino Motorshield running on 4AA batteries.
The motor is this one:
I am using (for now), this code:
I am using a linear pot to turn the motor speed up/down on A0, but it only gives me 3 stages; slow, moderate, fast. I don't have a fully at rest state, and I have no real speed control to find tune to my needs. My thought was that I would simply get the pot correctly running and it would sweep smoothly for speed control. Am I wrong that it should do that? I could use button controls to do what it does now (if I knew how to code them in).
Buttons are a lost cause for me, I can't figure them out, I've tried...talked to people about them....I simply do not understand the wiring that needs to be done for them or how to code them. I simply want 2 SPST NO buttons to control left/right control for now, and the pot for speed. After that is running I will work on the interface for timelapsing.
Can someone PLEASE help me out here? I can add you on facebook and repost here once I have it figured out so google can find it. I am simply lost on what I'm doing. I've done the tutorials on adafruit, but no luck on using them outside of the tutorials.
The easiest way to wire the switches (buttons are for shirts) is to connect one leg to ground and the other way to a digital pin. Then, turn on the pullup resistor on the pin that the switch is connected to. You can use:
Have you tried zips?
Velcro?
Seriously, there are plenty of examples, libraries even, to allow you to use simple switches.
Maybe I wasn't clear? I've done every button tutorial I can find. I simply don't understand this stuff, and would like to get my project moving forward. If I can get it working, I don't know if I will continue w/ Arduino or not...but I'd like to at least complete this.
A switch is a binary device; at any instant, it can be on or off.
Whether the "on" state returns a HIGH or a LOW to the processor depends on how it is wired.
If the switch is mechanical, it may exhibit a phenomenon called "bounce", where the natural springiness of its construction may cause it to return multiple different states over a short period of time, which may cause a very fast program loop to jitter as it reads every state until the switch fi ally comes to rest.
There are many techniques to debounce a switch, some hardware, some software
I'm not ofay with AccelStepper but a quick look at the library on the authors site an I cannot see an option for just 3 pin defininitions. Also you seem to be sharing one of the stepper pins with buttonPin. You setup but never read the buttonPin pin.
EDIT: A closer look and it seems the 2 is the number of pins so does not clash with buttonPin.
Also the command looks like it should be 'AccelStepper stepper(DRIVER ,3,12);' but someone else should confirm this.
#include <AccelStepper.h>
AccelStepper stepper(2,12,13);
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 8;
const int brakeB = 9;
const int buttonPin = 2;
boolean buttonWasPressed;
int buttonValue;
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
pinMode(pwmA, OUTPUT);
pinMode(pwmB, OUTPUT);
pinMode(brakeA, OUTPUT);
pinMode(brakeB, OUTPUT);
digitalWrite(pwmA, HIGH);
digitalWrite(pwmB, HIGH);
digitalWrite(brakeA, LOW);
digitalWrite(brakeB, LOW);
stepper.setMaxSpeed(800);
stepper.setSpeed(1);
pinMode(buttonPin, INPUT);
buttonWasPressed = false;
stepper.runSpeed();
int sensorReading = analogRead(A0);
// map it to a range from 0 to 100:
int motorSpeed = map(sensorReading, 0, 1023, 1, 1600); //1600 is the max speed of my motor
stepper.setSpeed(motorSpeed);
Serial.println(sensorReading);
AWOL:
Maybe if we could see your code, we might be able to help.
Oh well.
I posted my code in my first post. I figured that was easier than posting it here, but it's posted below now but another user. I've been staring at this for nearly a month, with little to no progress. I'm simply just trying to finish at this point.
How ARE your switches wired? What behavior do you actually see when a SMALL sketch reads the switch state(s) and prints them to the Serial Monitor application?
Last I tried a switch, when pressed it turned my whole board off. I don't know why or how. I stopped messing with it when I couldn't get a better outcome, so I came here.
This is what I've come up with, though I also got it working with a while statement. It works...but something is still off. Debounce may beI needed, I don't know. I rress the button and it moves, but it delays the release a lot of times.
const int pwmA = 3;
stepper.setSpeed(800);
pinMode(buttonPin, INPUT_PULLUP);
buttonState = digitalRead(buttonPin); // read state of buttonPin
if (buttonState == HIGH)
digitalWrite(buttonPin, HIGH);
digitalWrite(buttonPin, LOW);
stepper.runSpeed(); //stepper code goes here
