I have vaisala hmp155 humid, temp sensor. is there any way that i can read the output from this sensor using my arduino thru serial monitor? tnx in advance
This has been mentioned before (briefly):
http://forum.arduino.cc/index.php?topic=223204.0
Note it does claim to have a voltage output as well as RS485 (maybe that's temperature only though?)
Do you have the D or A/E model.
Tom.... ![]()
PASSIVE or ACTIVE ?
DID YOU READ THIS ?
YOU linked it so presumably you have it.
Why are you "struggling " ?
What is the problem ? (is it that you can't read or can't understand or both ?)
Did you read the section on interfacing the USB cable with the RS-485 pins on the 8-pin connector ?
